Olds 455 donor engine
Keith V
3,578
373
83
I have a non Toro 455 with a bad block, the cly bores are very rusted, it would need to be sleaved.
it has c heads, not sure if it has the good valve covers, not a Toro intake, crank may be OK
I'm planning on selling the heads and valve covers unless they are the good one and scrapping the rest
is there anything else I should salvage?
Keith Vasilakes
Mounds View MN
76 exRoyale
MicroLevelhttp://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf
Yes, the cam gallery plug on the rear of the block. It has a lube hole to
lube the distributor drive gear. Specific to the 455.
Salem, Oregon
> Keith Vasilakes
> Mounds View MN
> 76 exRoyale
> MicroLevel<
> http://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf>
Valve covers are valuable, intake manifold,
Jim Kanomata ASE
Applied GMC RV
> Jim Hupy
> Salem, Oregon
> > Keith Vasilakes
> > Mounds View MN
> > 76 exRoyale
> > MicroLevel<
Jim Kanomata ASE
http://www.gmcrvparts.com
If it is a non Toro and not from a GMC isn't the starter mounted on the
driver's side?
> Jim Kanomata ASE
> Applied GMC RV
> > Jim Hupy
> > Salem, Oregon
> it
> > > Keith Vasilakes
> > > Mounds View MN
> > > 76 exRoyale
> > > MicroLevel<
> > > GMCnet mailing list
> Jim Kanomata ASE
> jimk
> 1-800-752-7502
Bruce Hart
1976 Palm Beach
LaGrange, Wyoming
GMC=Genetically Modified Chevy
Starter is on the driver side and mounts to the block.
Toronado mounts on the trans on the passanger side,
Oilpan needs to be for the Toro,
> driver's side?
> On Thu, Jun 9, 2022 at 11:02 AM Jim Kanomata
> > Jim Kanomata ASE
> > Applied GMC RV
> to
> > > Jim Hupy
> > > Salem, Oregon
> rusted,
> > it
> the
> > > > Keith Vasilakes
> > > > Mounds View MN
> > > > 76 exRoyale
> > > > MicroLevel<
> > > > GMCnet mailing list
> > > GMCnet mailing list
> > Jim Kanomata ASE
> > jimk
> > 1-800-752-7502
> Bruce Hart
> 1976 Palm Beach
> LaGrange, Wyoming
Jim Kanomata ASE
