> > > Always start with the current ACDelco number and cross from there. The big block and 77 small block take a PF24 This supersedes the AC
> > > PF30 which was same but no anti drain back ). The PF24 comes over from Buick where the filter was horizontal and had to have anti drain back.
> > > This broader use of PF24 is for the simplification of SKUs The Wix cross over would be the 51258 which has anti drainback but no integral
> > > bypass. That’s good.
> > > The 78 small block uses the Smaller PF58 used on other small block Olds like 307, the Caddy Northstar and others. Wix is 51045. This
> > > number info is from GMCMI interchange.
> > > If you go to wixfilters you can cross reference and see all the specs. Burst strength, microns, flow, and if it has anti drain back, or if
> > > it has integral bypass. Get it first hand and current.
> > This is one of the odd differences between USA and Canada, I couldn't tell you where I could go and buy a Wix filter in this city.
> > I have never seen one on a shelf at any of the auto parts store I frequent. According to the Wix website, the nearest dealer is about 130km
> > away.
> Do you have NAPA auto parts? Not sure, but I have heard that the Napa Gold oil filter is made by Wix. Maybe someone out there can confirm. If
> so, do you have Napa?
Yup, as John confirmed below, Napa gold is Wix. So my Napa 21258 on the engine is actually a Wix and easy to get. Thanks guys.
I'm running into a similar thing trying to change the top on my Miata, the 3M adhesive I need seems to have changed a digit in Canada (08011 vs
80119). Have to confirm if it's the same stuff with them tomorrow.
Burl Vibert
Kingston, Ontario
1976 GMC 26 foot, Sheridan reno, don't know original model
> > away.
Burl Vibert
Kingston, Ontario
