Perfect Hupy.
Sully
Bellevue wa.
On Sat, Oct 12, 2019 at 7:13 AM James Hupy via Gmclist <
> Ah yes, the old corroded bolt trick. A couple that I use (more or less
> successfully).
> FIRST, BE KIND, GENTLE, AND PATIENT.
> One ticked off yank on the breaker bar, and you are in do-do right up to
> your neck.
> SECOND, penetrating oil and a pinpoint heat source are your friends.
> If you do not know them intimately, get to know them on a first name basis.
> It will serve you well.
> THIRD, LOW POWERED IMPACT TOOLS ARE YOUR FRIEND (or worst enemy,
> depending upon how aggressively you apply their use).
> So, open the hatch and spray your most effective penetrating agent
> (there are many of them out there, and everyone professes to have the
> secret mixture that will unlock anything and everything). Then, close the
> hatch and walk away. Come back tomorrow, and repeat. 7 days is not too long
> to repeat. NO JOKE. Give the stuff time to work.
> Put a 6 point closed end wrench on the bolt, pull the wrench and tap,
> tap, tap the end of the bolt with a hammer. If nothing budges, spray it
> liberally with penetrant and WALK AWAY. Come back tomorrow with determined
> resolve, and repeat the 6 point wrench trick. Try turning in both
> directions. If it moves at all, your chances of success just improved a
> great deal.
> I have a battery powered 1/4 inch drive impact wrench. It will rattle
> the hell out of those bolts, without snapping them off. I also have a
> jeweler's oxy/acetylene torch with a tiny pinpoint flame that I use. Be
> very, very carefull with flames under the hatch. Have an assistant with
> lightning quick reactions and a cool head standing by with a CO2 or Halon
> extinguisher when you do this. Absolutely not a dry chemical one. Apply
> heat to the bolt and get it hot but not red hot. Then spray a couple of
> quick squirts of penetrating oil on it. It might flare up briefly and smoke
> like mad. Just blow it out with your breath, and apply the impact tricks
> again. Repeat. BE PATIENT, you only have a stuck bolt. If you yank on that
> wrench with too much force, you will set yourself up for a whole bunch of
> work.
> Salem,Oregon
> On Sat, Oct 12, 2019, 6:35 AM Samuel Ferguson via Gmclist <
> > This is what I am going to have to deal with when I get brave enough to
> > start trying to remove exhaust manifold bolts.
> > Sam
> > Samuel Ferguson
> > Pittsfield, Illinois
> > (West Central Illinois)
> > 1976 GMC Palm Beach (A newbie who will not allow this thing to kick my
> > butt!!)
