Nice going, New gas line will also help because now it has a permanent
crimp. The Primer circuit will also help so that you do not have to crank
so long.
I would / did, not think of a crimped gas line.
gene
>I finally removed and cleaned my carb today, I think I have figured out my
>probs..
>When I took the gas line loose from the pump, no gas seeping out...1st flag.
>after taking the bowl loose, no fuel in bowl..2nd flag..
>cleaned inside of bowl, put a new gasket on, since the top 1/3 was 'pulled'
>down leaving a small gap at top of manifold..
>Also had a 'whoops' and a 'whew' when cleaning out the screen in the bowl.
>Had a can of carb cleaner and a can of gold paint sitting side by side..
>went to spay some carb cleaner on screen and though it funny that the fluid
>was gold colored...(Whoops)
>remembered reading on carb cleaner can that it will remove paint,
>so....(Whew)
>Otherwise that fixed my 'cycling problem.
>Ran it for awhile with/without load and ran fine..
>Pushed it in and ran it again..whoops, died after awhile..
>checked back gas line and noticed it would 'fold' up when I pushed it in..so
>started it outside, running ok. than pushed it..after a while it started to
>cycle and tried to die.
>I immediately pulled it back out and it recovered fine..
>Now I need to shorten rear gas line so it wont fold up..
>Otherwise. looks ok now..
>CBWood
>77 Kingslay
>(On digest, at home)
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
