Non-Yamaha BWS (aka Zuma) 50
Deb
358
6
3
Just to remind myself that life isn't ALL GMC, I decided it was time to get the wee scoot out of winter (HA!) storage and on the road. Been working
on so many hiccups in the coach that I haven't had time to get her out from under her cover).
Battery was pulled and inside for winter, topped up and in good shape; gas was treated so it is also fine. Starter cranks like a charm, but she won't
turn over. Tried the kick-starter and no luck there either. So... time to check the plugs for spark and see if there's fuel getting to her. After 8
attempts and giving her lots of throttle (2-stroke 2009) she wouldn't start but I would have expected to smell some gas by that point (would think she
would be flooding by then) however no gas smell. I think it's time to pull off the tupperware and look at the carb and the fuel lines. Wa-a-h!
:cry:
Like Roseanne Roseanna Danna used to say "If it's not one thing, it's another."
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
'77 Kingsley, 403, EBL EFI;
TZE167V101404
It's Bigger on the Inside!
> working on so many hiccups in the coach that I haven't had time to get her out from under her cover).
> won't turn over. Tried the kick-starter and no luck there either. So... time to check the plugs for spark and see if there's fuel getting to her.
> After 8 attempts and giving her lots of throttle (2-stroke 2009) she wouldn't start but I would have expected to smell some gas by that point (would
> think she would be flooding by then) however no gas smell. I think it's time to pull off the tupperware and look at the carb and the fuel lines.
> Wa-a-h! :cry:
Deb,
I'm going to jump in here because I have way too much experience with miniature two-stroke engines.
If you did not shut the fuel off and run it dry before you put her up for the winter, then the carburetor is plugged up in two probably places. Both
the needle and seat that regulate the fuel level in the carburetor and/or the main fuel jet will be fouled.
First, look at the carburetor bowl and see if there is a plug that can be unscrewed or a sideways screw that is there to be a drain. If you find
either, see if you can make it drain from the tank. If yes, then you know the needle and seat have a chance. If you run some new fuel though it, it
may (NOTE: he wrote MAY) be able to soften what has probably dried in the main jet. It just might start then and run (badly), but if you can get new
fuel though it, it might just run long enough to clear itself out. Then, you don't have to get the carburetor off to clean it.
Good Luck
Didn't do either of those Matt (:( mea culpa). Going to drain the tank this morning, pull the plug and put a ml of gas in the hole to see if she
fires before I start yanking tupperware. But given the lack of gas smell after all of those attempts, I do suspect that it is a fuel problem, so I
think I will have some dismantling to do. However, I think that will be easier for me to deal with than trying to trace a lack of spark. I am a
technician, like to work with my hands. Electrical is so NOT my forte.
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
And it is also POSSIBLE that an appropriately sized dose of Sea Foam to a tank of fresh gasoline will clear things up. It might take two (or even three) treatments to do the trick completely.
D C "Mac" Macdonald​
Amateur Radio K2GKK​
Since 30 November '53​
USAF and FAA, Retired​
Member GMCMI & Classics​
Oklahoma City, OK​
"The Money Pit"​
TZE166V101966
Sent: Monday, August 19, 2019 09:15
Cc: Matt Colie
Subject: Re: [GMCnet] Non-GMC: Yamaha BWS (aka Zuma) 50
> Wa-a-h! :cry:
Deb,
Good Luck
The plug was stuck yesterday - wouldn't move as easily as I would have liked it too. Didn't want to risk snapping it off. A bit of lube around the
plug overnight and she came free easily this morning. Put about a ml of gas down the hole, tried the electric start (barely cranked). Started after
2 shots on the kick-start tho'. Runs a bit rough (missing here and there) but MUCH better than I expected. So... emptied the tank, will add about a
half gallon of fresh gas and a bit of seafoam and see if that helps. The gas I took out looks pretty good, very pale yellow, no water rolling around
in the bottom, no debris. I'll slosh around some fresh gas in there and siphon it out too before I go any farther.
I guess I can safely put the insurance back on her ;)
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
Yeah, Deb, what Matt said. "shut the fuel off and run it dry before you
put her
up for the winter." I've done that with my emergency house generators
for years, and they crank right up. The small engine folks say to run
them under load every couple of months, so they keep working. I've never
done that, and no problems. Don't know about all the other folks that
may or may not do that fare.
RonC
On Mon, 19 Aug 2019 08:15:55 -0600 Matt Colie via Gmclist
> road. Been
> charm, but she
> > won't turn over. > Deb,
Matt answered:
> places. Both
> If you find
> fuel though it, it
> you can get new
> Good Luck
> Matt
Ron & Linda Clark
North Plains, ORYGUN
1978 Eleganza II
Hey Ron. I bet that those that run them every month don't run them dry (& fog them like Matt suggests). If its empty you shouldn't need to cycle the
gas through monthly to keep the carb from bunging up. I have 2 little Honda 2000's that I have converted to propane for back up at home. Easier to
deal with than gas in the winter in the dark. Doesn't go bad or bung up the system.
You can bet I'll be taking Matt's advice to heart end of this season. Save a lot of work next spring.
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
I just started my weed wacker (string trimmer) after letting sit for about 10 months with a full tank of gas. (I forgot to drain and run it last
fall. I managed to get it started on fresh gas but had to run in on partial choke. After about 10 minutes of full power and partial choke use it
decided to run correctly without choke. Whatever was restricting the gas flow evidently got dissolved and it took of running smoothly. I dodged a
bullet on that one. The 10% craponol fuel we are forced to use here, sure cleaned it out. Ethanol is a great cleaner (gas detergent) if you can get
it to run through the carb and engine long enough.
Ken B.
HI, Deb.
I finally got tired of having to refill the 5 gal gas tank on my
generator when the power was off for a long time, & got a dual fuel
genny. Works great....sort of. I have to whack the electric fuel valve
to make it work. Grumble, grumble, gripe, bitch complain.
Obviously, it's electric start. I can't even pull the rope on this one.
the one before it either. Suppose I'm getting old and weak???
Ron
Ron & Linda Clark
1978 Eleganza II
On Mon, 19 Aug 2019 22:33:59 -0600 Deb McWade via Gmclist
> to cycle the
> home. Easier to
> up the system.
> Deb McWade
> Logan Lake, BC, CAN
> "Li'l Sister"
> TZE167V101404
Ron & Linda Clark
1978 Eleganza II
Last weekend I went through the same exercise with my SIL's pressure
washer. He's used it for years without ever running the carb dry. It
finally caught up with him and his effort at cleaning the carb didn't help
-- it just wouldn't start. I finally had to completely disassemble the
carb, including the main jet and the venturi tube it retained, clean them
and all passages thoroughly with carb cleaner and reassemble it all. Ran
fine then. But, of course, before all that, we had to go through the
exercise with fouled plug, etc. :-(
DO run 'em dry!
This is my second season with this little scoot, first 'spring wake up'. I have no idea if the PO(s) ever ran it dry. So from the sounds of it, I
think I probably got lucky that it started and is now running. This fall I will empty the tank & run her dry - no manual petcock on this one - I
think, from what I can tell in my reading in the service manual, that it opens when the ignition is on. So I can't turn the fuel supply off and then
run her dry. I believe I can drain the bowl on it (again, still reading). I may be wrong. Still learning this one.
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
I think the 2 stroke BWS fuel supply is controlled by a vacuum valve. You
should be able to apply a vacuum source and drain.
But it's been a few years since I've messed with one and I'm in a "12
months a year" scooter zone...
Rob
76 Royale Twin Beds, Dry Bath
Victoria, BC
On Tue., Aug. 20, 2019, 8:20 a.m. Deb McWade via Gmclist, <
> Deb McWade
> Logan Lake, BC, CAN
> "Li'l Sister"
> TZE167V101404
Or you can make sure to fill with ethanol free and some stabil (make sure
it fills the carb)before you store it, disconnect and load the battery on a
tender and pretty much forget about it until spring.
Sully
Bellevue wa.
On Tue, Aug 20, 2019 at 8:27 AM GMC Motorhome via Gmclist <
> Rob
> Victoria, BC
> then
> > Deb McWade
> > Logan Lake, BC, CAN
> > "Li'l Sister"
> > TZE167V101404
> Rob
> Victoria, BC
Go ahead, Rob... Rub it in ;) Around here it seems like you just get things out of the winter hibernation, and it's time to think about putting them
back to bed. We don't take our winter tires off till May (late April if we push our luck) and they are generally going back on in September. I can't
plan on travelling anywhere in the coach unless I can be back by mid-September.
And don't even think about asking "Winter tires??" :lol:
Thanks for the vacuum valve info. Sounds reasonable from what I have gleaned so far. I will take a good look through the service manual - I still
have a couple of months to figure out the logistics before the snow flies.
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
> Sully
> Bellevue wa.
Good thought. I was actually hoping to fill the coach with it this past fall before putting her away. But ethanol-free is getting harder to find up
here. Used to be pretty much readily available. I checked our local stations. Nearest is 40 miles from me (that was last year - who knows now!).
But it would be worth the trip to fill the gas can just for things like that. Probably do it with the coach this year too. By the time I get her
home (40 miles uphill) I will have used some, but would still leave it in better shape than the EtOH10% with stabil.
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
In my BWS 2 stroke service manual - page 5-8 shows the testing procedure!
Rob
Victoria, BC
> Deb McWade
> Logan Lake, BC, CAN
> "Li'l Sister"
> TZE167V101404
Thank you Rob! I'll pull my digital manual out.
I just got back from about an hour tooling around our little town. I forgot how much fun that little thing is :) Got her up to a little under 45 mph
on the flat without too much trouble, even kept her above 30 mph on a decent hill we have here in town. Once I got the old gas out, ran some seafoam
through with about a half litre of fresh gas, and then filled it with fresh, she ran great. Missed a bit for the first 15 minutes or so at higher
speeds, but once things got flushed through, no problems. Also - amazing what a new battery can do! The old one would hold a charge, but just went
totally flat as soon as I tried to start. New battery Boom! Started right up first push of the button.
Just noticed I need milk. Might have to go out again :roll:
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
And for good measure, I emptied the old gas from my 2007 mp3 250, popped in the new battery, turned the key and she roared to life. No hesitation.
She has been sitting there since December 2016. Scooter gods are smiling on me today. :d If she weren't so darned heavy, I would have bought a rack
for that instead of getting the Yamaha. But a 500 lb scoot on a rack - there's that lever/fulcrum issue again. And I really don't want to tow
anything. I don't do well with backing up trailers.
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
An MP3 is likely fuel injected! A big difference - especially after sitting for a while.
I've got the same engine (Piaggio Quasar) in my Beverly 250 - mine has a carb...
Rob
Victoria, BC
> Deb McWade
> Logan Lake, BC, CAN
> "Li'l Sister"
> TZE167V101404
It is fuel injection. But I was still surprised that after all this time of sitting, it seemed to run like it was parked yesterday. Idled really
smoothly. We'll see how it all goes tomorrow when I get it out of the garage, onto the driveway and give her a good going over. Not much maneuvering
room in my garage.
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
TZE167V101404
