Looking for the picture of the little jumper cable that bypasses the neutral start switch on the column if you have column ignition switch problem
that results in no start.
Want to make one up just in case.......
Plugs in where the two purples wires go into ignition switch.
Finding the instructions for adding separate start button but not the instructions for the "get you home" jumper solution.
Pete
Cary, NC
1978 Center Kitchen Royale.
Pete
Cary, NC
