No Start
Totality
575
Looking for the picture of the little jumper cable that bypasses the neutral start switch on the column if you have column ignition switch problem
that results in no start.
Want to make one up just in case.......
Plugs in where the two purples wires go into ignition switch.
Finding the instructions for adding separate start button but not the instructions for the "get you home" jumper solution.
Pete
Cary, NC
1978 Center Kitchen Royale.
> Read here -
> http://www.gmcmhphotos.com/photos/push-button-start-switch/p50258-slide224.html
> Or here
http://www.gmcmhphotos.com/photos/data/6460/start_switch_talk.pdf
The tap is the easy way
Tnx Gary
> Gary Bovee
> Red Bluff, CA
> 1978 Royale
> www.gmcidiotsguide.com
> Free "Internet Idiot's Guide for GMC MotorHome Information"
Alternator Protection Cable
Thanks, I had found those....but neither has the details of the plain simple cable asm to bypass the neutral switch.
Pete
Cary, NC
http://www.gmcmhphotos.com/photos/gmc-cranking-improve-for-free/p34373-nss-bypass-jumper.html
ok found it....well at least one version. A simple wire with a male spade connector on either to jumper the two purple wire cable to the neutral
safety switch
the one I remember had three wires......so you can connect to 12v in case the 12v from the ignition switch is not good. I have connectors and wire and
can do that if needs be.
Pete
Cary, NC
