new vibration on acceleration (after steering pump swap)
ek_lektro
170
As we near the hopeful end of the Eleganza’s “to do list”,
I just had my leaking power steering pump swapped out, and now there’s a vibration when i accelerate, from 0 to 20MPH and then goes away.
It sounds as if the new pump isn't delivering sufficient presure/volume, and the pump pulses are shaking things. Maybe Alex or somebody knows how to
test for this...
Was the new pump bled correctly. I recall you have to install it, fill it a bit and spin the pulley without the belt on a few times to work the air
out of the system.
Mid Michigan
Clean the filter at the windshield wiper motor. Probably caused your leaks. May fix the vibration.
Hal Kading 78 Buskirk Stretch Las Cruces NM
Does it only vibrate when you are in motion or does it also vibrate parked reving the motor?
Roy Keen
Minden,NV
76 X Glenbrook
Under the universal heading of Been There - Done That....
I suggest that you eyeball the PS sheave and be sure it is not bent.
If you buy the beer, I will tell you the rest of the lengthy story.
OK cool Matt,
Would Amazon drop ship some beer? Perhaps by drone?
by “sheave”, you mean pulley, on the pump itself?
Yeah, when they put in the new pump, at first the pulley was slightly crooked.
I thought that this might be the source of the vibration problem,
so i came back and they loosened the belts and straightened
the pulley to 100%, but still the vibration / noise. no change at all.
The vibration can shake the whole front of the cab, and is hard to pinpoint the source (while driving),
but the noise does seem like it coming from the steering box more than the steering pump.
I should mention again, the box was rebuilt last month… just new seals basically.
And THEN, with a tight steering box, the steering pump leak got significantly worse.
So i was advised to try some stop-leak.
I asked if that might harm the new seals in the steering box, and was told No.
Asked a 2nd opinion, different mechanic… was told it shouldn’t be a problem.
Well,. maybe the stop-leak DID ruin some internal seal in the freshly rebuilt box?
I hate to think, but must speculate…
(and f that’s the case, then i’d be accepting beer donations to drown my misery.. and i don’t even drink.)
anyway Matt, I’ve got Prime
(if Amazon has beer)… and you care to tell your story;
Standing by :)
cheers!
Greg
Beside bleeding, which is a common problem on those, have you closely looked at every inch of the belt on the V side of it? A small chunk missing or
flaw in the belt surface could also cause your problem.
Hey, i’m happy to report that i found the cause of the vibration. It was the fan clutch, and my suspicion is that the Autozone Duralast 22045 (replacement for 2747) apparently didn’t come with the right sized spool (not the right length/depth); and while i was busy overseeing the steering pump swap, as well as the bodywork and paint job(!), the other mechanic put the fan clutch in without analyzing the spool difference. During troubleshooting, i couldn’t really “see” the fan clutch spinning out of alignment, but when it ended up failing (and staying on constantly), suddenly it all made sense. So i got a Hayden 2747 from OReilly’s, and now the vibration is gone!
.. which brings up another issue, perhaps regarding pump bleeding. after installation, we did the ole turn hard right / turn hard left, add fluid, repeat… bleeding… and i could’ve sworn that i checked the hydraulic wipers, and they were working fine (but not 100% sure). but anyway, i’ve driven about 160 miles since the swap was done, and now the wipers are not moving at all. But the steering seems to be fine, fluid level is fine, and no noise from the gearbox. but apparently there’s either not enough pressure, or maybe the filter is blocked? This is the pump we put in: http://www.oreillyauto.com/site/c/detail/MPPC/7322155/02869.oap?year=1975&make=Oldsmobile&model=98&vi=1215694&ck=Search_02869_1215694_-1&pt=02869&ppt=C0031
Well, the fun never ends, especially in Tijuana garages,
but where else can you get substantial bodywork and paint done in 3 days,
while they also work on the mechanical stuff…. and all for $750? (with me working alongside them)… https://www.instagram.com/p/BWEeHo5hRxn/?taken-by=solarsonic
Yep, its one of those 20 MPH paint-jobs… and the subject for a whole other post!
cheers all,
Greg
SolarSonic, back in the USA…
Greg,
If the filter was blocked so much that the wipers didn't work, then steering would be real hard.
Check that the cable is moving the valve on the wiper motor.
that’s what i thought…
good idea…
