New plastic gas tanks needed.
Bob Dunahugh
2,784
4
3
Aren't new tanks $800 each. I know someone that just paid $1,100 plus tax to get both his tanks cut apart, blasted, welded, coated inside, and painted. Painting the outside Doesn't help with condensation on the inside. Plastic would be great. Plastic tanks have been in service for decades. Bob Dunahugh
True dat. However plastic tanks are molded.
You would need to make a mold - perhaps from an old tank - because our tanks are one - off. Likely they'd have to be molded in two halves to get the
slosh baffles in them. Perhaps there's a way to make a fiberglass tank which is fuel proof? It would be a lot cheaper unless the molder could sell
several hundred of them.
And would need DOT cert which might be expensive. I wonder if any Caddy, Suburban, SOB, farm implement Tanks would work?
The problem is how shallow they have to be to fit inside the frame. There's really no better safe place than where they are. I believe someone added
a third tank, I don't know thw dimensions or capacity or plumbing.
Chuck Garton added a third tank a few years ago. He added a standard 25 gallon GMC tank by moving a crossmember and MO tying it forward. The third tank was just in front of the aux tank.
I believe there is a write up on the GMCWS web site.
Frederick, CO
> --johnny
> Braselton, Ga.
The depth of those tanks is real close, but you would need to install 2 pair.
OK, Left main then right main then left auxiliary and finally right auxiliary.
Or just leave on of them dedicated to the APU.
The depths of which tanks?
I didn’t see a previous on the GMNnet referring to those tanks. Which tanks are they and what is the depth?
> Matt
Early CJ Jeep tanks.. 6 1/2 inches.
https://tinyurl.com/ycfd2vke
jofarr, soddy TN - 3 26'
----- Original Message -----
Reply-To:
To:
Cc: Emery Stora
Sent: 9/5/2018 3:33:15 PM
Subject: Re: [GMCnet] New plastic gas tanks needed.
________________________________________________________________________________
Frederick, CO
> --johnny
> Braselton, Ga.
On our GMC MH Europe FB , Hekim Lokman, showed his new alutanks, self build.
Tomorrow I will try to link some pictures here,
Bye, Daniel
Daniel Jacobs, NL-USA (almost a) 1977 GMC Eleganza II, 455 newer Tranny+3.55 FD. FiTech and FCC, new Hoses, Selector Valve and Electric Pump,
insulated Tanks, APC, McDash, Dash AC to Enviro Safe. Schräder V+extern Fills, Ceramic Film TPMS FlexSteel Seats
Daniel,
There have been a number of fabricated tanks that have been available for the coach. Yours are the best that I have seen and the quality of workmanship is noticeable. The others produced in the US have been produced using light gage mild steel sheet to keep costs down. Aluminum is a great choice, but has gotten very pricey on this side of the pond.
JR Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 30’ Stretch
Michigan
> Here the link to the pictures
> https://handyman.stackstorage.com/s/b6puTChd7prmRKz
> https://handyman.stackstorage.com/s/WWyoqpokYwZBWfX
> https://handyman.stackstorage.com/s/ICrJ8OaXbv9qJHD
> Daniel
If there is somebody in the area of this manufacturer (Idaho) that has access to a defunct GMC MH tank, perhaps he/she could take it to this company to see if they can duplicate it!
D C "Mac" Macdonald​
Amateur Radio K2GKK​
Since 30 November '53​
USAF and FAA, Retired​
Member GMCMI & Classics​
Oklahoma City, OK​
"The Money Pit"​
TZE166V101966​
'76 ex-Palm Beach​
k2gkk + hotmail dot com
Sent: Sunday, September 9, 2018 18:04
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.tanksinc.com%2Findex.cfm%2Fpage%2Fptype%3Dresults%2Fcategory_id%3D59%2Fmode%3Dcat%2Fcat59.htm&data=02%7C01%7C%7Ca2d5e25d10f04d662d1308d616a9c894%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636721315795206621&sdata=VQXR1qPvjxqfls2lKyvkVKV50faV9492Pzo%2B0mt7KLk%3D&reserved=0
Iowa, not Idaho, FWIW
1974/94 GMCII by Explorer
Manny 6.5 TD Al radiator
1 ton front 4 bags back
OOOPS! Roger on IOWA for the new steel or even STAINLESS steel gas tanks.
Mac (weak eyes) in OKC.
(https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.tanksinc.com%2Findex.cfm%2Fpage%2Fptype%3Dresults%2Fcategory_id%3D59%2Fmode%3Dcat%2Fcat59.htm&data=02%7C01%7C%7Ca2d5e25d10f04d662d1308d616a9c894%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636721315795206621&sdata=VQXR1qPvjxqfls2lKyvkVKV50faV9492Pzo%2B0mt7KLk%3D&reserved=0)
Sent: Sunday, September 9, 2018 20:57
https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Flist.gmcnet.org%2Fmailman%2Flistinfo%2Fgmclist_list.gmcnet.org&data=02%7C01%7C%7C0e659e01618e49eefda008d616c0e2c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636721415017158796&sdata=J7cBtY%2B%2FiMmZO7w9WXxNTEd1WyoCLZvWzUcwcTSBvuQ%3D&reserved=0
I have sent the following to the manufacturer. Maybe I will receive a reply!
Mac in OKC
Sent Message:
"There is a considerable market for replacement fuel tanks for the 1973-1978 GMC motorhomes. These are relatively flat and somewhat squarish tanks that are maybe 6" deep and baffled to reduce fuel shift. I suspect that someone in your geographical region could provide a rusty one that could be cut up and a pattern made. Of the original approximately 13,000 of those that were built, the whereabouts of over 8,000 of them are known and probably well over 1,000 are currently on the road. More could be put on the road if replacement fuel tanks were available."
Sent: Sunday, September 9, 2018 21:14
To: jeff sugheir; gmclist
Mac,
They are not far from the GMCMI rally in AMANA. They are NE of Cedar Rapids. Between Cedar Rapids and Dubuque,IA.
After asking, Hekim told me, he payed about €800 ... for that Alutank, handmade (Euro)
He could also have had it made of Stainless,.
Making this choice I think was not bad, since shipping them to Europe will be also very costly.
And it became some bigger so, in combination with a Liquid gas installation, it is more then enough.
Daniel
