In Oct we woke to 18 deg and snow out west on I90. A bit below expected but not unheard of. You can't control mother nature. My stock 195 worked as it
should. As it did 2 days earlier in 85 deg and dash air running. And as it should pulling long grades over the majestic Rockies. An engine that dies
from overheating is ultimately the fault of the nut behind the wheel. If you can't feel the characteristics in drivabliity in an overheating engine
and check your gauges, maybe you should only drive a Prius. Given some of the poor longevity of some Mondello engines in MH service duty, maybe a
good 195 stat would have helped Washer = stoneage
Source America First
