Mondello Cooling Restrictors
john r. lebetski
4,659
2
In Oct we woke to 18 deg and snow out west on I90. A bit below expected but not unheard of. You can't control mother nature. My stock 195 worked as it
should. As it did 2 days earlier in 85 deg and dash air running. And as it should pulling long grades over the majestic Rockies. An engine that dies
from overheating is ultimately the fault of the nut behind the wheel. If you can't feel the characteristics in drivabliity in an overheating engine
and check your gauges, maybe you should only drive a Prius. Given some of the poor longevity of some Mondello engines in MH service duty, maybe a
good 195 stat would have helped Washer = stoneage
John Lebetski
Woodstock, IL
Source America First
When we ran in flat motors at Mac's on a test stand, we watched oil temp. There's a pronounced drop when the rings seat. Then we'd pull it off the
stand, put dessicant plugs in one set of spark plug holes, and ship it.
--johnny
Braselton, Ga.
"The road goes on forever, and the party never ends" --Robert Earl Keen
> GOPOHERIT
> mine does not keep the engine cooler.
> runs 180 all the time
> just do not run the engine hotter for the heater ----
> does not make sense to me to do that
> no big deal , do what you will
> erf
In our first GMC, we were doing the Vermont fall colors. One morning we were freezing. Thermostat was stuck open or had junk in it. I stopped at the
first auto parts and got another thermostat and some antifreeze. When we began to drive the warm air from the heater was great.
I use EFI and it judges fuel mixture based on, among other things, water temperature. I don't want my rig running rich in cold weather just because it
thinks it has not warmed up.
When I helped Armand Minnie put in his current engine he got a fail open thermostat. Sounded good to me. There is no way I would drive with a "washer"
stuck where the thermostat is supposed to go. Makes no sense to me.
Remember, racing engines are torn down constantly, hence the different sizes of restrictors.
But, hey, this is America. Do as you feel best.
'74 Eleganza, SE, Howell + EBL
Best Wishes,
George
On Sat, Jan 21, 2017 at 10:41 PM George Beckman
wrote:
> GOPOHERIT
> erf
I feel it is shameful to cook your 455 just for a heater !!!
it
TURNS OUT, MANY OF US USE 40 YEAR OLD COMPUTERS FOR OUR EFI
I USE HOWELLS ON 2 OF MY 3 GMCS. AND THEY USE THE " WORSTE INJECTORS EVER
MADE"
http://gmc49ers.blogspot.com/2014/12/my-atomic-1973-23.html
ACCORDING TO WITCHHUNTER
http://www.witchhunter.com
SO I DONT NEED ANOTHER BATTLE TO WORRY ABOUT !!
TURNS OUT A THERMOSTAT CAN - ONLY HEAT AN ENGINE- MY MONDELLO RUNS AT 180
, AFTER ONE MILE FROM HOME
"washer"
I NEVER THINK ABOUT THERMOSTATS , ONE LESS ISSUE
Best Wishes,
George
Very interesting thread! I think I'll stick with my 195 stat. I read every post, I think I need to take a few tylenol now.
If I going to drag race a GMC I'd go with Mondello's recommendation but I'll
stick with the thermostat that has been used in BILLIONS of street vehicles.
Regards,
Rob M.
The Pedantic Mechanic
USAussie - Downunder
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Ray
Erspamer
Sent: Monday, January 23, 2017 3:04 AM
Subject: Re: [GMCnet] Mondello Cooling Restrictors
Agreed. It’s a whole different thing trying to “cool” an engine used for drag racing!
Dolph
DE AD0LF
Wheeling, West Virginia
1977 26’ ex-PalmBeach
1-Ton, Sullybilt Bags, Reaction Arms, 3.70 LSD, Manny Transmission, EV-6010
> Regards,
> Rob M.
> Erspamer
> To: gmclist
GEEE: In Northern Canada, our cooling restrictors look like this. ;>》
http://www.gmcmhphotos.com/photos/discussion-photos/p62088-cooling-restriction-cold-weather.html
At -25C the heater core is almost more cooling capacity than needed for some of the engine operating conditions. The coolant in the Radiator gets
so cold that when the thermostat opens so much cold water comes into the engine that it can never warm up.
The cooling system of our vehicles are designed for extreme conditions (look at the size of our radiators and fans!!) The thermostat is designed to
adjust the amount of cooling for the engines needs.
Removing it and letting free flow will simply over cool the engine when not needed. It's my feeling that if your engine gets up to temperature
without a Thermostat then the capacity of the cooling system is insufficient for extreme conditions and has been restricted in some way. Much the
same we purposely do in the north during cold weather.
John and Cathie Heslinga
1974 Canyonlands 260
455, Manny tranny and 1 ton, 3:70 LS,
Red Seal Journeyman, DTE, BEd. MEd.
Edmonton, Alberta
