Lower radiator hose with spring
scott nutter1
729
According to the parts interchange index, the lower radiator hose Napa #8796, does not have the metal coil spring inside it.
Does anyone know the maker and part number for a molded hose with the spring?
Thanks, Scott.
Scott Nutter
installed MSD Atomic EFI
Houston, Texas
Can you just reuse the spring from your current hose? I haven’t run across one that was ever molded in, they were all just slipped inside.
-Dave
1978 Transmode near Pittsburgh
> Thanks, Scott.
> Scott Nutter
> Houston, Texas
There are several on Amazon. Search for radiator hose spring.
Some auto parts stores also have them
Emery
> -Dave
>> Thanks, Scott.
>> Scott Nutter
>> Houston, Texas
Interesting tidbit..
I went to the local Napa today. They had a flex hose in the trash area. We cut it apart, and low and behold the flex hose was a giant metal spring.
then the rubber was formed onto and around that. This is the flex hose with the screw pattern.
So what I think I've learned is that if you are using a hi flow water pump, then the flex hose would be the one to go with. Napa part # RM15 for a 455
(made by Gates).
I do remember molded hoses with the metal coil on the inside, but seems that people weren't crazy about that because the coil could rust and damage
the water pump.
Scott.
Scott Nutter
Houston, Texas
The convoluted radiator hoses should be your last choice, because they put
constant tension on the radiator inlets and outlets. If molded hoses with
loose STAINLESS STEEL springs inside are not available, then use the
convoluted hoses as a last resort. Those connections on the radiator are
only soldered in place on the brass radiators, heli-arced on the aluminum
radiators. Either way, they are fragile.
On Mon, Sep 23, 2019, 2:42 PM Scott Nutter via Gmclist <
> a 455
> (made by Gates).
> the water pump.
> Scott.
> Scott Nutter
> Houston, Texas
If the coil rusted then everything else in the engine would rust or corrode. It would be immersed in antifreeze and if they changed it every two years the coil would not rust.
> (made by Gates).
> the water pump.
> Scott.
> Scott Nutter
> Houston, Texas
> The convoluted radiator hoses should be your last choice, because they put constant tension on the radiator inlets and outlets. If molded hoses
> with loose STAINLESS STEEL springs inside are not available, then use the convoluted hoses as a last resort. Those connections on the radiator are
> only soldered in place on the brass radiators, heli-arced on the aluminum radiators. Either way, they are fragile.
> Salem, Oregon
James my good man,
That is a nice plan, but during last year's refit I searched for a molded to fit hose or one that could be made to fit and came up with nothing.
If someone has a number and source for such a hose, please get it to the parts substitution book for the next update.
Matt - who will be filling a cooling system tomorrow
The convoluted hoses also encourage a lot of turbulence and thus flow reduction. As Jim said, they should be a last resort.
What do our vendors recommend and offer as a lower hose?
Les Burt
Montreal
'75 Eleganza 26'
>> Jim Hupy
>> Salem, Oregon
> James my good man,
Matt, JimK shows two different sets of molded hoses. But surely you knew
that! What are we missing?
And here is an inner support spring:
https://www.npdlink.com/product/spring-lower-radiator-hose-keeps-the-hose-from/143875
Rick “whose NAPA hoses still have the labels on them, last I looked” Denney
On Mon, Sep 23, 2019 at 7:50 PM Matt Colie via Gmclist <
> James my good man,
'73 X-Glacier 230 "Jaws"
Northern Virginia
I got OEM hoses from Jeff Sirum.
> > hoses with loose STAINLESS STEEL springs inside are not available, then use the convoluted hoses as a last resort. Those connections on the
> > radiator are only soldered in place on the brass radiators, heli-arced on the aluminum radiators. Either way, they are fragile.
> > Jim Hupy
> > Salem, Oregon
> James my good man,
C. Boyd
76 Crestmont
East Tennessee
I just got molded hoses from Gateway GMC parts but I don’t think they have a spring in the lower, so is it going to collapse if I don’t add a spring?? We did install a high flow water pump on the new engine (Cardone pump wasn’t available).
Rick Drummond
1974 26’ (re)Painted Desert named B.O.B.
>>> Jim Hupy
>>> Salem, Oregon
>> James my good man,
> C. Boyd
> 76 Crestmont
> East Tennessee
The spring just kept the hose from colapsing under decelleration because as the water slowed the hose would vacumm in. Also the hose itself didnt have
very much structual support so the spring also kept it in "shape".
Todays hoses have braiding molded into the hose material itself.....much better and stronger to the point we can even use silicone hoses, mold them
into any form we want and use them without internal support etc.
In the industry i work in we have such high thermal cycling and flow in the engine we now are degrading inside of the hoses ...its so bad Gates now
makes a "grey" hose which is made of something totally different materials to stop it.
Lomg story short....if the new modern hose doesnt have a spring it probably doesnt need it.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Thanks Rich that makes me feel better.
Rick
Rick&Tammy Drummond
Prior Lake MN
'74 (re)Painted Desert named B.O.B.
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
I am not sure why you want these springs. It is my understanding that they were there to prevent collapsing the hose during cool down when a slight
vacuum is present sucking coolant back out the overflow container.
When the vehicle is running The entire cooling system is pressurized to what ever the radiator cap is set to (7 to 16 PSI. When the vehicle is running
marginal difference in pressure between the intake and output side of the pump and definitely not enough to over come the 7 to 16 PSI. The pump is a
high volume low pressure pump.
So I see no need for the spring and I personally have never seen a collapsed radiator hose.
> Rick "whose NAPA hoses still have the labels on them, last I looked" Denney
Rick,
If that is the case then the way it is listed in the interchange book needs to be changed. I buy enough from JimK that it would not bother me.
Matt - Gets to refill his cooling system today and maybe put the coach on the ground.
We provide the spring to insert, go to our heating cooling section.
On Tue, Sep 24, 2019 at 6:24 AM Matt Colie via Gmclist <
> Denney
> Rick,
> the ground.
Gates told us the spring is not needed as it was a factory coolant fill machine fixture.
I agree the system pressure would keep it inflated. The weight of the coolant head above it should also keep it inflated during cool down. The tiny
return spring on the return valve poppet is very weak. I ordered NAPA upper/lower spares to keep under the sofa in case of hose failure. If I had to
do a road side swap I'd leave the spring out as an experiment . Not a fan of the convoluted universal hoses. Even worse fan of the cosmetic braided
fake race Jegs stuff.
Ken B if the spring was to keep it from collapsing during cool down, then you would need one in the upper hose. Especially in the upper hose as the
weight of the coolant head above the lower hose would be more than what is on the upper.
The problem only arises with the high volume water pumps as I understand
it. Caused from pressure differential is a guess on my part. I know me
Son's jeep Cherokee with the high output inline 6 would overheat without
the spring in the lower radiator hose. Used the same hose with a spring
installed, and no problems, even in Arizona heat. Go figure.
On Wed, Sep 25, 2019, 4:49 PM John R. Lebetski via Gmclist <
> on the upper.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
The lower hose tend to collapse as it is the low pressure side.
I refer it as a phonomana when the lower hose does collapse when engine is
hot.
I run the coil as a preventative devise.
On Wed, Sep 25, 2019 at 4:56 PM James Hupy via Gmclist <
> Salem, Or
> is
> > on the upper.
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
