Lower Balljoints
jim wagner
1,040
When I replaced my lower balljoints I welded a small plate to the top of
the control arm where the balljoint is bolted to. I then bolted the new
balljoint on using the nut and two 5/16 bolts. When the joint was tight
on the control arm I removed one 5/16 bolt and tapped out the hole with
a 3/8 tap and installed a 3/8 bolt using red loctite. I also used a nut
which I tack welded to the bolt. I then did this to the other bolt. No
loose balljoint, no cracked control arm, no worry.
The other Jim 7GB 500Cad
> In a message dated 4/12/2000 8:34:03 PM Eastern Daylight Time,
> For those of you who would like to see what Jim did I took 2 pictures of his
> control arm they are on photo point
> http://albums.photopoint.com/j/AlbumList?u=202164
> Scott http://members.aol.com/adohen1/page/Fan-tastic.htm t=_self] [/url]Nhttp://members.aol.com/adohen/advice/index.htm t=_self] HREF="http://members.aol.com/adohen/advice/index.htm">EHODA'S BACK YARD[/url]
Is the reinforcement a ready made item, or custom? Either way, what's the
availability?
Wayne
WAYNE NEWLAND Phones 301-596-2484
6506 Spring Plow Lane 410-995-6629
Columbia, Maryland 21045-4650 Fax 410-381-3013
E-Mail: wayne
ON THE ROAD AGAIN!
F9300
1975 Palm Beach
ARE YOU SPENDING YOUR DAYS DOING WHAT
YOU LOVE TO DO? CHECK THIS OUT!
http://www.5pillars.com/maximus/
To:
Sent: Wednesday, April 12, 2000 8:33 PM
Subject: GMC: Lower Balljoints
> In a message dated 4/12/2000 10:51:00 PM Eastern Daylight Time, wayne
> > availability? http://albums.photopoint.com/j/AlbumList?u=202164
> Hi Wayne!
> Jim made them up himself and welded them on top--the one in the picture is an
> extra he made--Maybe Jim could make a template by tracing? I could scan it,
> print it out, I could check the dimensions, add the actual measurements of
> the piece for downloaders to check their printed template and, post it on a
> website or just e-mail it to those who would want it. The piece doesn't seem
> to hard to make. Maybe Jim will chime in on how he did it.
> Scott
> Fan-tastic Vents
Or we could let Leigh Harrison mass produce them in perfection.
Wayne
E-Mail: wayne
ON THE ROAD AGAIN!
F9300
1975 Palm Beach
