I should have prefaced this by saying I started with a Howell system. Howell's wiring harness had a small interface board that buffered the 12V pulses from the TACH connection on the HEI coil down to 5 volt (TTL compatible) pulses. This is the same board that some on GMCNet incorrectly said it was was to "fool" the 7747 into thinking it was connected to a knock sensor.wait what?
Does this apply to the Tach signal from an HEI distributor?
I'm pretty sure I just ran it directly to the ECM
The EBL board MAY have included a buffer that allowed direct connection to the 12V tach pulses.
