Forum Sharing ! this is what i have done. taking the Toyota headlite conversion ( 81110-60p70) with h4 bulbs. modified the OEM bucket to fit the dust cover. purchased led, h4 replacement bulbs from ebay.. opt h4 9003 led kit..144 watt 12 amps 7600 lumen per bulb at 6000k ,,although cheap under $30( I do not recommended them had to a lot of fussing to get the bulbs to be properly aligned and secure.. VERY IMPORTANT ).. but the Toyota assemblies are fine and the led bulbs do work. did have to trim the dust cover rubber to clear the led bulbs cooling fins.. i was a little concerned about 55 watt vs 144 watts cooking the Toyota wiring harness. .checking ... the relays are good for 22-30amps ( 40 %) and the fuse at 20 amp (60%). all new wiring harness using only the existing system to just signal the new relay to operate no load per say on OEM wiring. the driver side headlamp more expose than pass . made an additional dust cover from a plastic coffee container cut it to fit drills some vent holes and installed for added protection. ( not shown). any project like this need to be monitored over time and use to insure success..total headlite project under $100 ..looks good right now yours larry
