We spray painted black first then silver to make the headlight trim look better.I just installed a set of Bosch H4 headlights, I still might need to aim them properly, but so much better than sealed beam.
Anyhow, I have a question about headlight surround trim, has anyone refinished/painted them? Ours are in decent shape, but could use freshening up.
This is the best review of LED headlights I've seen:To all those looking at headlights. I have had metal reflector European code headlights for many year. These were not all the same headlights. Most were 7", and all that lasted long enough (most) failed due to corrosion of the metal reflector.
Did I like them?
Oh yes, even with 55Watt QI bulbs, they were all bags better than most all the DOT headlights. Beware that in states that have a real safety inspection (many on the east coast) these headlight will not pass and may get you a citation. The best ever to my liking were the Cibie Z-Beams. As good as they were, they car still out lasted them in the Michigan salt. I do not believe these are still available.
I have those, when HELLA was still making them in Germany and Hungry work great throw a nice beam. See if you can get the ones with DOT stamped on them the others are European and throw the beam to the left.
That's the same as what I mentioned above, just mine are Bosch. Euro are ok for beam pattern, UK isn't. DOT is of course ok in NA. Sometimes you can/should install a connector extension with higher heat rating.I have those, when HELLA was still making them in Germany and Hungry work great throw a nice beam. See if you can get the ones with DOT stamped on them the others are European and throw the beam to the left.
Wow! Thanks for sharing!!!!If you are thinking about the H3 bulb conversion kit above, I had a really hard time getting good contact between the GMC harness and the H3 bulb so I picked up a set of these..
Nice tight connection and a little extra room to tuck the harness out of the way when getting to the batteries and other things.
