Best guess is that Emery put my distributor at 14 degrees, then when you
do that, go find a hill, a steep hill, one that would cause it to
knock. Then adjuct the screw on the eke to where it gets one ping then
stops. On the eke, be careful, as the whole distance of travel is only
about 180 degrees, so a little (1/16 turn) goes a long way. thats how
we did it with emery's help.
al
> Bob,
> Wow! 1/2" is a lot of advance. I been
> waiting on doing mine (till we get a
> cold rainy day so I can't ride the H-D).
> Also I haven't been able to find my
> timing light! Have (had?) a real nice
> Sears one but I dunno if I loaned it to
> someone and they didn't return it or it
> just finally decided to up and walk on
> me.
> Out of shear curiosity I thought I
> would check my timing first to see where
> Jim had it set. Then I'll advance it to
> about 12-14 degrees with the EKE it
> should do it all for me (as I assume
> you must have decided as well). Thought
> I'd use a center punch or chisle and
> peen a light mark right at about 10
> degrees advance on the distributor and
> base just incase I want a reference to
> go back to on the road should the EKE
> ever go south (been my luck as of late,
> ya know...
> I am adding my EKE module under my
> drivers seat. I'll also add those male
> and female quick connectors as Emery
> mentioned on the cut wires to plug in or
> bypass the EKE and go back to stock if
> need be. Great idea, Emery!
> Sure would be interested in the
> optimum settings used on the module
> (those of you that have the Caspro EKE
> installed). Might give me a good ball
> park to start with (or they maybe all
> over the board too).
> Nate 75GB Omaha
> From: "Bob Mclaughlin"
> Subject: RE: GMC: Knock Sensor
> Gary,
> I just installed one from Caspro last
> night. Moved the timing forward half
> an inch on the distributor (no timing
> light). Road tested it once. It
> works. I still have some tweaking but
> it looks like it will allow me to
> comfortably run regular gas anywhere.
> I'd like to hear from anyone that has
> run it for several years.
> Bob McL
