Kitchen drain-line and the lower drawer service bulletin
Don Jaksa
577
393
63
While working on my kitchen, I noticed that the drain line was loose and it looked like someone had tried to seal it up in the past.
Typical 1973 kitchen module with two drawers
While checking cable clearance...and I noticed drainpipe movement when I closed the lower drawer
The #2 drawer is clearly striking the clean-out cap and causing stress on the drain line
It shows on the back of the drawer
And some 50 year inter-action on the clean-out cap itself
While enjoying the thread about GMC #22 in the museum and I looked at the pictures and behold
The lower drawer is notched to accommodate the clean-out cap.
I am going to notch my lower drawer to match #22
This discovery says something about your sharp eye and the thoroughness of Karen's photographs!
Weird that they notched the drawer back in the very earliest model but not in the later 73s. 🤔
Wonder why they didn't just switch to a flush clean out plug?
On further inspection, I cannot "cutout" enough drawer to accommodate the clean-out because it sits lower and would compromise the drawer integrity
Work-around:
I just flipped the clean-out cap, inserting the "sticking-out" part inside and tightened it down with a 1x1 piece of wood, which fit the slot perfect
It does not block the drain-line when flipped
I am running some 12vdc LiFePO4 battery stuff and was making sure the drawers did not interfere
I also noticed that have to restore the plastic drawer stops and some other pieces
details...details
Reactions: dsmithy
I got my parts from ROCKLER
I also purchased new hardwood runners to match the glide
You have to notch the wood at the point where the drawer drops into the track, but easy enough
I can't find the drawer drop pieces that keep the drawer closed but I could make those or just repair the existing ones
