Ken,
Why did you not contact me as I could help along with fer others that are
available .
I helped 3 people today.
> Replace the 7 pin module.
>> does the fuel pump come on when the key is turned? It should come on for
>> a second.
>> The wire to the starter tells the ECU the engine is cranking, hard to
>> believe it would kill the ecu
>> BUT, if that wire is not connected to the starter I doubt the ECU would
>> start the engine since it wouldn't know you are trying to start it.
>> That said you should still get spark, since the spark isn't controlled by
>> the ECU, just the timing of the spark. Kinda points to the module or the
>> pickup coil
>> maybe unplug the knock module.
>> Definitely call jimk in the morning
>> ________________________________
>> From: Ken Shaffer
>> Sent: Monday, September 6, 2021 10:01 PM
>> To: gmclist
>> Subject: [GMCnet] Re: Ken Sheffer stuck on I-90 in SD. Needs some advice
>> Update…
>> I’m off the interstate. I got a Tow to Chamberlan SD.
>> I still have no spark.
>> Have 12v to coil. I replaced coil and dist cap, then replaced
>> distributor. Still no spark.
>> I have Howell EFI with EBL
>> Anybody have any other suggestions?
>> Thanks,
>> Ken
>> Ken Shaffer
>> Marion Iowa
>> 73 Canyon Lands, 455, Micro-level, Alum radiator, Alcoa wheels, Lenzi
>> hubs/bearings, Howell EFI/EBL, Rostra Cruise, Custom interior
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
>> GMCnet mailing list
> Jim Kanomata ASE
> Applied/GMC, Newark,CA
> jimk
http://www.gmcrvparts.com
> 1-800-752-7502
Jim Kanomata ASE
