Dan,
Chances are you don't really have a problem. Unless your PO installed a
multifunction switch on the steering column, or designed his own electrical
system, you should have what I call a Push-to-Wash/Twist-to-Wipe (PtW/TtW)
switch. It has a 1" diameter black knob with a Wiper & Washer logo on its
face. Somewhere nearby should be a smaller knob on a rheostat. The switch
has OFF, LO, and HI positions. OFF is pretty self-explanatory. LO runs
the wipers at low speed but also enables the rheostat to impose a delay
between sweeps. I'm afraid I haven't been very consistent in how I've
wired the rheostats: Some increase the sweep DELAY when turned ClockWise,
others increase the sweep FREQUENCY when turned CW. I kind of figure
either becomes second nature after about one use. The HI position on the
PtW/TtW increases the sweep speed to almost too fast, and disables the
intermittent sweep feature.
Let me know what you figure out & whether you DO have a problem.
Americus, GA
www.gmcwipersetc.com
On Fri, Sep 20, 2019 at 12:42 PM dan molnes via Gmclist <
> Turned all the way to the left is when it occurs parked or moving , not
> sure what position the switch is on I don't know where the switch is , P.O
> did the install I can go out and look a little later , thank you so much
> Sent from my iPad
> > On Sep 20, 2019, at 9:10 AM, Ken Henderson via Gmclist <
> > Dan,
> > I need a little more information to have any hope of helping: When is
> the
> > 1 minute intermittent occurring, with the PtW/TtW switch in the OFF, LO,
> or
> > HI position? Where's the delay rheostat set, Fast or Slow?
> > Ken
> > On Fri, Sep 20, 2019 at 11:38 AM dan molnes via Gmclist <
> >> Ken my wiper intermittent keeps swiping every min or so any ideas as to
> >> why thanks Dan Molnes
> >> Sent from my iPad
> >>> On Sep 16, 2019, at 5:33 PM, Ken Henderson via Gmclist <
> >>> Ohhh! That's there 'cause it came not from "GMC Wiper Set" but from
> "GMC
> >>> Wipers, etc." ! When I chose the name, I thought there might be some
> "et
> >>> cetera" items to sell. Now that I no longer make ride height links, I
> >>> guess the "etc" (or just the "c") should go away, huh?
> >>> Ken H.
> >>> On Mon, Sep 16, 2019 at 8:22 PM Charles Boyd via Gmclist <
> >>>> The "c" between gmcwiperset and .com
http://gmcwipersetc.com/
> >>>>> Chuck,
> >>>>> I used HER computer and got on. I still don't see the problem. Huh?
> >>>>> Ken H.
> >>>>> On Mon, Sep 16, 2019 at 7:15 PM Charles Boyd via Gmclist <
> >>>>>> Ken, I just noticed after all these years, how your electric wiper
> >>>> kit
> >>>>>> web sire was spelled.
> >>>>>> C. Boyd
> >>>>>> 76 Crestmont
> >>>>>> East Tennessee
> >>>>>> _______________________________________________
> >>>>>> GMCnet mailing list
> >>>>>> Unsubscribe or Change List Options:
> >>>>> GMCnet mailing list
> >>>> C. Boyd
> >>>> 76 Crestmont
> >>>> East Tennessee
> >>>> GMCnet mailing list
> >>> GMCnet mailing list
> >> GMCnet mailing list
