Jim Bounds Sliding driver windows
Alright and i hear you.
So the last set of used "modern style" windows for the whole coach i saw for sale they were asking 6K. Now i like the look of the new windows but at 6
plus thousand i really like my originals.
So what are the solutions then: [in my mind anyways]
A- you keep looking patiently and find them one at a time etc with the understanding that it wont happen soon and don't care about the cost
B- as you stated....figure out a new way to get air into the coach to which i have seen a couple solution....not my preferred method of doing
things...as a mechanic and fabricator i'll never cut holes in a firewall to bring air into a passenger compartment.[think about the "fire" part]
C- have someone fabricate something that you envision
So on point C:
How about having someone make you a set of electric windows that go up/down like a modern car? In todays age of skilled custom fabricators its not a
stretch really. If you put it into perspective it's really just two side channels, a top channel and a bottom. [which we need anyways for
strength/support for the windshield]....so think car door minus the hinges as an example. The glass could maybe be be sourced and cut from perhaps a
modern highway coach flush mount side window or a transport truck with the correct curvature. I believe their is enough space in the lower window area
for the guts of the window regulator.
Would it be worth it? What would you get out of it? Well that's for you to decide but i'm going to fathom, unless you do it yourself, you'd be into it
for well over 1500.00 and it probably will net you exactly what happens with a modern car...lots of wind noise when its open but little air flow but
i'm not an aerodynamics engineer.
So this puts us back to "point C"..... how about pulling it from the front roof section just were the clearance lights are.....think roof scoop used
on Class One GTP cars and rally cars. It can be blended in nicely, look modern, doesn't have to be big etc...heck if you dont mind loosing a little
bit of the space above the sun visors you could even make it raise and lower into the roof and you could even use the cut roof piece as the scoop.
[think 1930's pickup truck with the cowl vent you would pop up].
Guess my point is.... their are no "off the shelf" "cheap" "easy" solutions to get more outside air into the cockpit area or have that "arm out the
window" driving thing that use to be popular before modern car design has come about....in my opinion, if thats what you want, you'll be fabricating
it.
> The wings are installed as directed, but it not a real issue. the real issue is getting sufficient air flow though a cat door that was really a
> design failure. in is in the wrong location, and in an akward location to boot.
> I am finding on this coach that after weeding though all the information you have to pick and choose those items that seem to fit each individual
> coach owner best. the concept of redirecting wind via a plastic scoop though an most insane small opening a cat would not use to walk though is
> insane thinking. now are the roof hatches open yes , in the AC field one knows that you can only fill as much air in a room as will fit unless you
> have an opening to exhaust or one install and exhaust fan. so It goes to say you cant get air in a coach after it is pressurized unless there is a
> place for it to escape. that said the design of the cat window is BS and a GM fail and you can only get so much air in a 6 x 6 hole.
> option , cut to holes in the floor to bring infresh air via an air scoop on the front of the grille. Is hacking into the coach the real answer
> that should have been engineered in from the beginning? we should have better options. this coach back in the day was the premier coach and today
> still is in my opinion. we should have solutions to be on par with our coaches design. A cat door for a window is not a design solution. I am tired
> of hacking on my coach. I mean the average cost of any repair or upgrade on the coach is $1500.00
> so are there is no solution any more to have a real window?
Rich Mondor,
Brockville, ON
77 Hughes 2600
I find that if I open the rear windows a few inches, I get airflow throughout the coach, front to back. It flows out the toll windows. As long as
there's air movement, I don't care about the direction except it's an interesting phenomenon.
> as there's air movement, I don't care about the direction except it's an interesting phenomenon.
> --johnny
Johnny,
Funny you should mention that. I had noticed that a some point, and then at Mary's request, we got wind wings.
What to be cautious of is.... opening the rear windows a little, setting the wings in the "Suck" mode and then hitting highway. I never knew we had
that much stuff loose in the coach.
I usually have a dog or two along, which limits both the opening and loose stuff - since everything which might be attractive to the dog is put up and
that's pretty much everything loose. I do get a constant stream of white fur going by though.
We find that putting one wind wind out n one in pulls all that heat from the windshield out the wind wing sucking out. Works for us.
Sent from my iPhone
> --johnny
> Braselton, Ga.
Grant,
Why not repair the dash ac system and leave the windows closed?
Sully
Bellevue wa.
On Fri, May 1, 2020 at 11:32 PM Grant Schaffer via Gmclist <
> design
> insane
> that you can only fill as much air in a room as will fit unless you have an
> cant get air in a coach after it is pressurized unless there is a place for
> it to escape. that said the design of the cat window is BS and a GM fail.
> on the front of the grille. Is hacking into the coach the real answer that
> options. this coach back in the day was the premier coach and today still is
> design. A cat door for a window is not a design solution. I am tired of
> hacking
> is $1500.00
> So who is the company that was making the windows? what can a one off cost
> $3000.00? buy the time i am done breaking in my new motor and installing it
> there will be more that $10,000 in to include the mondello roller set up
> ill never use. so whats $3000.00 for real side windows?
> Sorry for the soap box. Its real exhausting to not have real solutions.
> 1974 GMC Sequoia 26'
Never thought of that, Jeanette. And I bet didn't anyone else either. Honest show of hands, how many of us thought to do one frontwards and one
backwards?
WHo's for hanging vortex generators on the windshield corner along the bottom? Make it look like a Lear 23 :)
> backwards?
> --johnny
NO on the vortex generators, but we tried the one in and one out thing just once and the resulting hurricane was not what we had in mind and it also
proved to unstable and difficult to control as we were not on a straight road so out air speed and attack angle was changing.
Has anyone thought of gauging any remaining interest in the full size sliding windows by trying to organize a group buy? Maybe contact Jim and see if
he would be willing to run off another set of windows if someone would do the legwork and get a group of paying buyers together. This way, he
wouldn't bear the burden of having his own inventory, space, and money tied up in another run....
Unfortunately, while I really like the idea of the full size windows, I for one seldom use my windows at all, and when I do, the windwings move enough
air for my needs. Here in TX, I'm mostly running the AC if I need ventilation. Because of this, while I'd still love a set of the full size windows,
it's lower down on my priority list of things to do to the coach.
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
You call JimB so he can give you the quantity.
You’ll not like the quantity and the frustration of a group buy.
They want money up front as the glass are curved.
Jim B and I are always looking for people that want to finance this type of
project.
I financed these and the Framless and the cockpit, but not this go around
when JimB informed me on quantity needed .
On Mon, May 4, 2020 at 8:22 AM Mark Sawyer via Gmclist <
> see if
> enough
> windows,
> Howell Injection,
> Fort Worth, TX
http://www.gmcrvparts.com
I'm going out on a limb here but i bet he has a couple sets in stock for "his" use.....so what i mean is if you were to drive your coach there and say
"JimB, install me some of them cool big windows" he'd say "sure, can do, at an installed price of $$$$".....but if you called him a said "JimB, how
much for a set of them cool big windows shipped to me?" He'd say "soory don't have them anymore".
Have you called him and asked "how much installed and i think i"d like you to install those fancy flat ones too if you can find some"? Put a bit of
meat on the bone and the dog may bite. ;)
Rich Mondor,
Brockville, ON
77 Hughes 2600
How many do they want to make?
Jim B told me he does not have any left.
I have one left, but for my other coach.
Knowing what I know today , you will not want to bite on it.
I have one on my Kingly also and like it a lot.
On Mon, May 4, 2020 at 11:40 AM Johnny Bridges via Gmclist <
> --johnny
> Braselton, Ga.
> in hell
Your probably talking about 100 sets as a min run. Could be more! Say
production wholesale is $600 then the layout cost would be $60K +/- up
front. Jim K told me recently that the suppliers no longer want to do
small runs and even 100 might be a stretch.
J.R. Wright
GMC Great Laker
GMCGL Tech Editor
GMC Eastern States
GMCMHI
TZE Zone Restorations
78 Buskirk Custom 29.5' Stretch
75 Avion (Under going Frame up Restoration)
On the road tomorrow back to Michigan social distancing all the way!
> --johnny
> Braselton, Ga.
> in hell
If the price is right I’d be interested; yet as one said, they are low on the priority right now. Fuel lines, fire suppression, and rear suspension upgrade are the priority.
Randy
Chaplain Randy Hecht
Roswell, GA
Chaplains are ready to Listen when you're ready to talk.
1974 Canyon Lakes GMC the Unicorn Express
80mm Front Disc and a work in progress
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
> The full height sliders look nice and are nice for talking to someone, but they don't flow air any better than the little ones.
> 80mph down the road with them open and nothing is coming in, it's just a function of the shape of the front end of the coach.
> The wind wings are the only way to get decent airflow.
80 mph...Holy Crap! 8o I am lucky to get to 45 mph then fight to keep the motorhome driving straight. It goes in to the shop in 2 months to check the
rear bogies, front steering box installation and then install Tru-Track.
So, I just replaced my leaking cab side windows with the last set of Jim Bounds tall windows (Alex Sirum GMC) and it seems to me that there is a lot
more air coming in. Now I have the daunting task of replacing the passenger floor due to wood rot from the leaking window.
Good luck finding a set.
Ed Clerkin | 1974 GMC Canyon Lands 26’
ED, Since you have one, you know first hand as to how it works and feel.
I know of a Lady that put on wind wings. She knows how it works.
Yes full height. used two on each, I think.
I have one on my 78 Kinsey and one in storage for my 530 Cad Royal.
On Thu, May 7, 2020 at 4:00 PM Ed Clerkin via Gmclist <
Ed, Call me re. your handling issue.
We have learned from Alex F as to what to check for so you can drive it
with one finger.
>> the
> Jim Kanomata
> jimk
> 1-800-752-7502
> with one finger.
> Jim Kanomata
> jimk
> 1-800-752-7502
I will certainly call you. What day/time is better for you?
Also, I was working with Nick on a rectangular headlight order but it sounds like the source that made it has retired. Any chance of a another source?
Ed
Call me any time as I can always return your call should I be away from my
office. Best # 800-752-7502
On Fri, May 8, 2020 at 11:29 AM Ed Clerkin via Gmclist <
> > with one finger.
> > Jim Kanomata
> > jimk
> > 1-800-752-7502
> source?
> Ed
