Here is a response to a request for a price on a remanufactured 455 CI
engine for my GMC which I sent to Jasper. Thought it might be of use to
some folks.
Per your request the following information applies:
This engine is going to be remanufactured back to or exceeding
O.E.M.
specifications. It will consist of the remanufactured block, heads,
cam, crank, and
rods. It has a standard set of new internal parts that include:
pistons, rings,
bearings, lifters, valves, valve springs, and timing components.
Included with the
engine will be the oil pump, oil pan, and the timing cover. These are
already installed
on the engine for you.
After the engine is built-up, we then LIVE RUN TEST it at the
factory to make
sure that it is going to be running properly when you receive it. We
actually pour the
fluids in and run it for 1/2 hour to 45 minutes. While it is running we
run checks on
oil pressure, vacuum, and compression. We also check it for any leaks
or noises. This
JASPER complete engine will be backed with a 3 YEAR / 50,000 MILE
WARRANTY. This warranty covers PARTS AND LABOR and is good NATIONWIDE.
The price on your 1974 GMC Motorhome 455cid carb engine is $2434.00
exchange.
If you would like to get this engine on order, or if you have any
further questions
please call my sales department at 1-800-827-7455. Thank you
some folks.
O.E.M.
cam, crank, and
pistons, rings,
Included with the
already installed
factory to make
actually pour the
run checks on
or noises. This
exchange.
further questions
