In tank fuel pump question
Matt Colie
11,101
807
113
South East Michigan near DTW
Ken,
I am going to address your issues inline for two reasons (even though I don't like doing this):
A - It should be clearer in the final reading.
B - I am a little lazy about some things....
> I will begin the process of fixing fuel delivery issues on my motorhome. The previous owner (my Grandpa!) let it sit for a bit too long. It has
> trouble getting fuel from the tanks all the way to the carb.
> **Given the age and condition of the coach, I would bet that the rubber lines on top of the tank have become porous.**
> It will start and run just fine on a small tank strapped to the bumper. So I want to drop the fuel tanks, verify they are clean, and begin to
> replace everything that might need replacing due to age and ethanol.
> **This is not a terrible job (wrote the guy that had his tanks down 5 times until he got it right). I will send you my notes on methods and what
> I have learned if you would like. (That is really just me hoping to save someone else four tank services.)
> I will likely run with the carburetor for a few years before possibly looking at fuel injection - that said - I'd like to make life as easy as
> possible on myself once this is done. I live in Northern California, where it gets very hot in the summer (well above 100). I want to minimize
> vapor lock as much as possible with the carb setup, so I will be looking to:
> 1. Potentially rebuild carb
> **The word rebuild is over used here. Just buy a kit, read the instructions on the Rochester site, clean it and put it back on. GENTLY
> **Ask us before trying to remove it. The filter plug is easily damaged and expensive to repair.
> 2. Insulated carb to fuel pump line
> **This is the one line that is under pressure and does not really need insulation. OR at lease it didn't help me much.
> 3. New Gates Barricade fuel lines all the way around
> **Very good plan - It has been good for me.
> 4. Polyarmor hard lines at least on top of the tanks
> **Also a good plan that was kind of a pain but I don't have to worry about the rubber on top of the tanks again.
> 5. New fuel tank selector valve
> **What you have is probably junk, most are but the replacement is upside down and backwards and take some creativity to install.
> 6. New manual fuel pump
> **Do not do this if you are going to in-tank pumps or any electric pumps *** More down the page
> 7. New in tank electric fuel pumps - https://www.gmcrvparts.com/product-p/gm12-007.3.htm
> **If going to TBI this is a good idea. More down the page - again
> 8. Access holes in floor to facilitate electric pump service in the future.
> **This can't hurt.
> Has anyone used the above in tank fuel pumps? They seem like the easiest, quickest, and maybe best path forward? Any other advice, or
> parts/pieces I might be missing?
> Thanks,
> Ken
Getting away from the engine driven pump is not all bad, but many have had success with low pressure (for carburetor) pumps mounted low in the frame
where there is very little lift height (negative pressure) to deal with and they are easily serviced.
If you mount a pump for each tank, you can eliminate the selector valve with a little additional control and then have built in redundancy. If you
later go to TBI, the pumps will want to be in the tank for cooling.
When you arrived here back in January I warned you that we all have this agenda that is to see to it that you get to enjoy your coach and what it can
do for you. All you have to do is ask and you will get the benefit of a truly awesome amount of experience. (I, by the way, am a piker in this
crowd.)
Please keep us apprised of your plans and ask us before you spend money.
When JimK said call him, he meant it. He knows about these things and knows what the good parts are.
If your reluctant to call me for advise, your wasting your time in many
cases. Should I feel I cannot assist them, I usually refer them to others
that I feel is more capable.
There are areas of the coach I do not like to dabble in , so I let Nick or
others handle it.
On Wed, Apr 22, 2020 at 4:49 PM Matt Colie via Gmclist <
> Ken,
> long. It has
> to:
> future.
> > **This can't hurt.
> > Thanks,
> > Ken
> crowd.)
> Matt
http://www.gmcrvparts.com
For in-tank pumps, if you stay with the carb you will need low pressure pumps. Then when you change to EFI, you will need to change the pumps to high
pressure units. So you might want to save the $250 for low pressure pumps and goto EFI now.
just saying.
Bruce Hislop
ON Canada
Sounds like my wife.
Spend $1k to save $250. ;-)
Naw, I know what your talkin about. Just had to comment. Gave me a grin
bdub.
On Thu, Apr 23, 2020, 7:27 AM Bruce Hislop via Gmclist <
> high
> and goto EFI now.
> just saying.
> Bruce Hislop
> ON Canada
Ken m, here's a setup that cured vapor lock in the Southeastern summertime:
http://www.gmcmhphotos.com/photos/g6198-cane-9-creek-rv-park-heflin-2c-al.html
Note that this uses the existing line which ran originally from the selector forward and the lines that come from the tanks. Which you should replace
if they haven't been. Note the fitting on the hardline to the carb and the blank flange to the side of the block. If you carry a spare mechanical
pump, you can revert to stock beside the road in a matter of minutes should this become necessary. There are two caveats: First, run the pump power
either through an oil pressure switch or a Ford mid - 00s safety switch. The Ford switch is a somewhat easier install but both will shut the pump off
in an accident. Second, replace the supplied filters with a pair of Wix replacements. The chionee filters fail at the swaged
connection and draw air.
I've personally no great favor for in - tank pumps, my MSD injection wants ~~ 50 PSI which it gets from the supplied in - line pump attached to the
frame rail inside. It's given no trouble in three years. I will note however, I finally pulled out the spare pump the PO had, and looked at it. Low
pressure fro a carbureted engine. I'll be replacing it
--johnny
Braselton, Ga.
Oh and let me point out for the uninitiated, I'm personally two things which are anathema to most of our GMCers:
1. Cheap
2. Lazy
These dictate a fair amount of stuff I do to my coach including the listed fuel system uupgrade.
--johnny
Braselton, Ga.
Check to ensure in-tank fuel pumps have built in check valves. If not you will need to install in-line check valves.
HTH.........
Glenn
76 Glensbroke
