We all know that the original cool air intake is the one on the right, with the open air dimensions of 3"x8 1/8". It has an open area of 24.57 sq in feeding a 4' dia (12.57 sq in) flexible hose with two 90° turns that increases air resistance substantially. The compression ratio is 1.97.
The stock opening is 2 1/2" so visualize the modification to cut out the entire flat section to get the full 4" opening for the air hose.
My proposed 11" x 8" eliptical air intake has an unrestricted area of 276.5 sq in feeding the 4" dis tube with no turns. The compression ratio of this arrangement is 21.99, almost 11 times the original design.
This must help both engine with carbs and fuel injection engines.
This is my COOP 455 with the old carb.
This is it now. Quite an improvement.
The filter has been moved to where the old air intake used to be.
It will soon be inclosed and protected with this assembly, but what is it?
The screen cage is........
A stainless steel kitchen strainer and .......
the elliptic scoop is a heavy duty gasoline and diesel funnel.
Both a readily available and inexpensive.
The filter is washable, so it can be cleaned and reused. Rain water will not affect it.
The screen will protect the filter from debris and bug juice.
The filter can now be service from the front of the coach.
What do you think of my new "AIR RAM".
