Holding Tank Capacity
richard waters
1,236
> OEM holding tank on the GMC is 40 Gallons capacity.
> J.R. Wright
> > A friend of mine is contemplating replacing his decrepit old holding tank
> > with a new one. Ardemco has a tank for the GMC similar to the original;
> > capacity is listed as 30 gallons, about the same as OEM.
> > He is speculating that more capacity would be very desirable and wonders
> > about using a deeper tank. One that is 1 1/2" deeper would increase
> > capacity to over 40 gallons.
> > Glenn
> > 78 Kingsley II
John,
Are you sure of the holding tank capacity? According to the
owner's manual for my 1976 GMC Motorhome the Holding Tank
has a capacity of 32 gallons. The Living Area Water Tank has a
capacity of 40 Gallons.
I'm pretty sure of the fact that the water tank holds more then the
holding tank. The reason I know that is because back in December
I took my neighbor up to Sandusky to pick up his 1973 23' Canyon
Lands from Cinnabar after having its engine overhauled.
To make a long story short we left with full water and hot water tanks
and an empty holding tank. My neighbor used the toilet in the way up
and managed to leave the pump and sink faucet on. When we arrived
in Sandusky, the water tank was empty and we had about 2" of water
on the floor of the bathroom. So I'm real sure that the 40 gallon water
tank holds more then the holding tank. At least that was the case in
my OEM coach.
I was real lucky that the holding tank contained only water from the water
tank. It would have been a real mess if that had not been the case :(
My apologies you are correct.
J.R. Wright
GMC GreatLakers
Michigan
> > J.R. Wright
> > > Glenn
> > > 78 Kingsley II
> John,
> my OEM coach.
John,
This is about the first time that I have been
right about anything regarding the GMC. I guess
I've learned something during the past 18 months.
Richard
> J.R. Wright
> GMC GreatLakers
> 77 Eleganza II
> Michigan
> > > J.R. Wright
> > John,
> >I
Holding tank capacity is 32 or 33 gallons thru 1977 and nominally
40 gallons in 1978. Cinnabar has the 40 gallon tanks as replacements
for all units. They don't really hold 40 because they use a rubber insert
that requires the pipes to extend down into the tank a short distance.
Wes is full of crap when he tells you how easy the installation is.
However, after the installation is done, it is a tremendous improvement.
Gary Kosier
To:
Sent: Monday, February 07, 2000 1:17 PM
Subject: Re: GMC: Holding Tank Capacity
> > J.R. Wright
tank
original;
wonders
> > > Glenn
> > > 78 Kingsley II
> John,
> my OEM coach.
> Gary Kosier
I had my holding tank replaced by Cinnabar last Summer. I'm
sure that I didn't get the 40 gallon model. They never mentioned
to me that there was a bigger tank available.
It was a major project for two of their guys to replace mine. I'm
very happy that they did it instead of me. Especially since the
first one leaked after installation and they had to take it out and
replace it with another new one.
I stood by and watched the whole thing. Even though they knew
what they were doing it took them more then 4 hours to R&R the
first one. I can just imagine how much FUN I would have had if
I had done it in my driveway.
The one issue that comes to mind immediately, is that the bottom of the
tank is 1 1/2" lower. This means that the outlet is that much lower and
therefor you will have less of a slope to the sewer hookup. I know in my
coach (being as these are already low to the ground) this is a major issue
when hooking up.
If the majority of your camping is without sewer hookup it is worth it.
But if you typically have a hookup, for me I would rather pull the valve a
couple more times than deal with poor flow and thus possible clogs.
Just my two cents.
Rick
76 Birchaven
- -----Original Message-----
Sent: Monday, February 07, 2000 11:31 AM
To: gmcmotorhome
Subject: GMC: Holding Tank Capacity
Hi Netters,
capacity
to over 40 gallons.
We were looking under the coach last night and it appears it would be easy
to
do and there'd be plenty of clearance. The biggest task would be to
fabricate a new center section of the crossover frame to accomodate a lower
outlet pipe.
Does anyone know if a larger capacity tank can be used, what the downfalls
might be, and what advice you might have for installing one?
Thanks in advance. It sounds like a pretty good idea to me.
Glenn
78 Kingsley II
Ondependence, OR
The whole situation gets worse when you add
reprocessed Beer, coffee and or soda to the holding
tank, even if the water and holding tank capacities
match. We found out the hard way years ago.
>J.R. Wright
>GMC GreatLakers
>77 Eleganza II
>Michigan
capacity.
> > J.R. Wright
decrepit old
holding tank
similar to the
original;
as OEM.
very desirable and
wonders
deeper would
increase
> > > Glenn
> > > 78 Kingsley II
> John,
According to the
Tank
Tank has a
holds more then the
back in December
1973 23' Canyon
overhauled.
and hot water
tanks
When we arrived
about 2" of water
the 40 gallon
water
> my OEM coach.
only water from the
water
not been the case
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
> I just went thru the holding tank system, rebuilding the slide gate valve and added a macerator pump and hose assy. along with modifing the 4" drain system to have either method available for use. Mine is very simular to this layout.
> http://www.web-access.net/~bmassey/macerator/index.html
> It helps to powerclean the tank before you start. If your tank is kept clean, then it will work and drain correctly, but if you have a build up in the tank you should consider a good cleaning.
> J.R. Wright
John,
Looks like you two have the best of both worlds! Neat setup.
I have some questions:
1) Is the point of the pump to be able to dump at more
places?
2) How long does the pump take to empty the tank as
compared to the old fashioned way?
3) How about winter time? It seems like the pump would
be very susceptible to freezing. Last December my holding
tank gate valve froze up and I had to use a hair dryer
to thaw it out in order to dump. That sure was a lot of
FUN! Now I don't camp in the cold weather.
4) Right now I dump at my neighbor's. He has a dumping
station in his driveway. Would the pump speed things
up in terms of cleaning up etc.
5) Was it as easy to install as it looks?
This is the number one mod to most GMC's
On my site I show about 3 different mountings. It is not that hard but oh
so good to dump.
gene
to this layout.
>> J.R. Wright
>John,
> places?
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
>so good to dump.
>gene
Great pun Gene! ROTFLMAO!
Chuck
Richard,
> > J.R. Wright
> John,
> places? YES! I CAN EVEN PUMP THE POOP INTO A TOILET IN
HOUSE AND EMPTY THE TANK.
> compared to the old fashioned way? EMPTIES THE TANK
IN ABOUT 3 MINUTES.
I DON'T CAMP IN COLD WEATHER, BUT I WINTERIZED MY HOLDING
TANK JUST LIKE THE REST OF THE WATER SYSTEM. I FLUSH IT REAL
WELL DRAIN IT AND ADD ANTIFREEZE.
> up in terms of cleaning up etc. MUCH LESS MESS!!
REALLY WASN'T TOO BAD, I PROBABLY SPENT A TOTAL OF 6 TO 8 HOURS, BUT
I MADE THE BRACKETS FOR THE PUMP SUPPORT AND ADDED AND EXTRA DUMP
VALVE \
AFTER THE PUMP TO USE THE REGULAR 4 IN DUMP LINE. REALLY A NEAT INSTALLATION.
J.R. Wright
GMC GreatLakers
Michigan
Rick,
If you will look on page 24L-1 in the X7525 shop manual, which covers
the 75 & 76 motorhomes, it says approximately 32 gallons. I believe
that all the GMC interior motorhomes thru 1977 had the same basic
tank, with the different part numbers reflecting the different locations
of the openings. In the June 1995 issue of Cinnabar's BMC Motorhome
News Wes explains that the 78 model tanks are approximately 40
gallons and the current version comes without openings in the top so
that it can serve as a replacement for all GMC interior coaches.
My tank was screwed up at the factory; the first guy tried to fix the
problem with a quart of silicone. My attempt was a bit better, but
the pipes were in a strain and eventually it broke the top of the tank
I got tired of the puddles and the smell. It is possible for one person
to replace the tank out in the driveway, but it does involve a lot of
profanity. But now it's dry where I park.
Gary Kosier
To:
Sent: Tuesday, February 08, 2000 10:28 PM
After dumping and flushing, fill holding tank w/ clean water and then pump
it all into a 55 gal. barrel (with macerator). When all punped, measure
depth vs. total to determine quantity.
Haven't switched to macerator? Do it now!
Dave (& Dege), '76 Royale, Santa Barbara, CA
> Gary Kosier
This is getting interesting for me! I went back and looked at that
issue and read that article. It would appear from what Wes wrote
that the new holding tank they sell holds about 40 gallons.
However, as I mentioned earlier, I left home recently with full
fresh water and hot water tanks on a recent trip. The holding
tank was empty. My neighbor used the toilet and managed
to leave the bathroom faucet open and the water pump on while
we drove. When we got to our destination the contents of the
fresh water tank was in the holding tank and on the bathroom floor.
There was also about 1" of standing water on the floor of the bath.
I don't think the hot water tank has anything to do with this as
the pump should stop pumping as soon as the fresh water tank
empties itself of its 40 gallon contents.
Based on that I could only conclude that my Cinnabar holding
tank does not hold as much liquid as the fresh water tank.
I guess I'll have to empty the holding tank and pour a
known quantity of water into the toilet until it fills. Then I
will know the exact capacity of the holding tank.
> Richard,
> VALVE \
> J.R. Wright
John,
Thanks for all the information. This sounds like something I will do this
Summer.
Richard
Nice job, worth several thousand words!
Tony
To:
Sent: Wednesday, February 09, 2000 5:33 AM
> TO WHOM IT MAY CONCERN:
> I PUT SOME PICTURES OF HOLDING TANK WITH BUBBLE TALK ON MY WEBSITE FOR MY
> SIDEBATH 75 PB. IF INTERESTED THEY ARE AT
> http://members.aol.com/adohen/advice/Variousphotos.htm
> I think the label on my tank verifies the fact that mine is 32 gals--
> SCOTT NEHODA'S
> BACK YARD
since all the other pictures are there, I looks like your link to the LOGO
picture is just wrong... may be pointing to the wrong directory or maybe
you did not click the box that says leave the picture where it is ?? I
think it is just a link problem ?? hard to tell from this side.
gene
>In a message dated 2/9/2000 6:51:00 AM Eastern Standard Time,
>> PS your top LOGO is broken on the page
>Thanks Gene-- I know --That is the reason I have been up all night--still
>can't figure out what is wrong--maybe some hackers are trying to shut down
my
>websites--any ideas?
>Scott NEHODA'S
>BACK YARD
mr.erf
Richard,
Hi, guy! Say, why would your pump shut off when the water runs out? I was
draining my system this Fall (we never really haven't had any winter yet
here in "The Big O", just been a long fall) and noticed my pump would sit
there fat, dumb and happy running till it burns itself out if I'd let it.
Just curious is all... Take care.
Nate '75GB (Man, those Jim K. 3.55 gears are great!) Omaha
PS. Speaking of long Fall, I've ridden the ol "Bad Boy"
http://www.tconl.com/~chase/images/badboy2.jpg three times this year
already. I'm even taking a mental health day today (they own me a bunch for
Y2oK). What with 60 degrees here yesterday and forecast of the same today
you know where I'll be this afternoon (60 degrees = 60 MPH) =8-). There is
something to be said for not tearing the bike down every year! Guess I'll
just have to tell everyone that it's last years model (g).
> Richard,
Hi Nate,
Ah yes, I have to be careful of what I say. I should have said that the pump
was running when we shut the motorhome down. But nothing was pumping
because the tank was empty. Does that make more sense?
Too bad about your lack of Winter. Do you want us to send you some of
ours?
Richard
