> OEM holding tank on the GMC is 40 Gallons capacity.
> J.R. Wright
> > A friend of mine is contemplating replacing his decrepit old holding tank
> > with a new one. Ardemco has a tank for the GMC similar to the original;
> > capacity is listed as 30 gallons, about the same as OEM.
> > He is speculating that more capacity would be very desirable and wonders
> > about using a deeper tank. One that is 1 1/2" deeper would increase
> > capacity to over 40 gallons.
> > Glenn
> > 78 Kingsley II
John,
Are you sure of the holding tank capacity? According to the
owner's manual for my 1976 GMC Motorhome the Holding Tank
has a capacity of 32 gallons. The Living Area Water Tank has a
capacity of 40 Gallons.
I'm pretty sure of the fact that the water tank holds more then the
holding tank. The reason I know that is because back in December
I took my neighbor up to Sandusky to pick up his 1973 23' Canyon
Lands from Cinnabar after having its engine overhauled.
To make a long story short we left with full water and hot water tanks
and an empty holding tank. My neighbor used the toilet in the way up
and managed to leave the pump and sink faucet on. When we arrived
in Sandusky, the water tank was empty and we had about 2" of water
on the floor of the bathroom. So I'm real sure that the 40 gallon water
tank holds more then the holding tank. At least that was the case in
my OEM coach.
I was real lucky that the holding tank contained only water from the water
tank. It would have been a real mess if that had not been the case
> J.R. Wright
> > Glenn
> > 78 Kingsley II
John,
my OEM coach.
