I'm looking at replacing the "stock" (OK, after 50 years probably few of us are still running the original 63A alternator) with a higher output unit capable of operating a DC-DC Lithium battery charger without over-taxing the alternator. I recently realized I was mistaken in thinking the high-output alternators were only available in "1-wire" configuration.
So, which 12V units have you used or looked into to replace the existing 63/80/100A unit currently installed in your coach? I'm not looking for 24V or higher, 1-wire, or second alternators; just what can easily replace the existing 3-wire unit (with perhaps a modified support bracket if needed).
There are a few listed on Amazon and eBay; "200A" that are 180A when you read further, if those numbers can be believed. I assume if I get one of those I should either buy two or at least keep one of my original units handy, just in case...
There is the Jim Bounds video from a few months back showing the Delco 21SI (apparently already discontinued) and custom bracket. Anyone tried it?
Do you use one standard belt, a double-pulley, a "toothed" pulley/belt, something else?
Looking for options. Thank you!
