SOLVED!!!
Thanks everyone for all the suggestions and help. The annoying buzzer was
easily found once I was able to un-attache the dash cover and expose the
wiring. The buzzer appeared to be wired to the "Low Fuel" TellTale light
using very thin wires. The buzzer was exactly where I suspected it to be;
pressed directly against the plastic shroud carrying air from the
HVAC system, which was a perfect resonator, amplifying the noise to an
uncomfortable level.
I cut and insulated one of the wires leading to the buzzer, and that
immediately killed the offensive gremlin. The Fuel Gauge (and all other
instrumentation) still displays correctly. Those of you that reported that
our coaches have only a low fuel warning light, but do not have a low fuel
buzzer were correct. This small but loud buzzer was clearly a PO
modification.
We will be taking the coach out for a run this weekend. It should be just
far enough to lower the gas tanks to the point that should trigger the low
fuel warning light, as it has done on those rare occasions when stretching
out the miles before filling up with fuel, seeking better fuel pricing
further on down the road. These past experiences have set off both the
buzzer and the warning light. It is interesting that this current
malfunctioning only affected the buzzer, without the ever turning on the
yellow Low Fuel TellTale warning light.
I'll report back on how lowering the fuel on this upcoming trip affects the
warning lights.
Special thanks go out to Steve Wienstock, Carl Stouffer, and Jerry near
Virginia Beach, for explaining how to get the dash off. And yes, someone
had already cut away the material in the upper left corner, making the
reinstall a piece of cake!
Vern
On Wed, Nov 13, 2019 at 8:50 PM Mike Kelley via Gmclist <
> Vern:
> Oops - follows should read following!
> Mike
> Sent from my iPhone
> > On Nov 13, 2019, at 8:17 PM, Vern Crawford via Gmclist <
> > Thanks Carl,
> > I was in town today, and by the time I returned home it was both too
> late,
> > and the weather too cold to want to deal with the coach issue. 'Tis time
> > for homemade chicken soup and bread.
> > Tomorrow I shall follow your and other great GMCers advice. I'll again
> > tackle removal of the dome covering the wiring, using gentle but firm
> force
> > to get it off and out of the way. I'm certain of "where" the blasted
> > buzzer is, and that will clear the way for me to either demolish the
> noisy
> > rascal, or to be able to trace wiring revealing clues to what sets the
> > trigger, and take other corrective action.
> > With any good luck at all, my next post to this thread should be able to
> > report on my findings and resolution to the pesky gremlin.
> > With fingers crossed,
> > Vern
> > On Wed, Nov 13, 2019 at 7:24 PM Carl Stouffer via Gmclist <
> >> Vern,
> >> The back dash cover kind of snaps into a channel on the dash donut and
> >> clips into slots at the front near the windshield. Once you get that
> >> removed,
> >> it should be easy to locate the offending buzzer and disable it.
> >> Once you get it off, cut it like the picture Steve shared (above) if it
> >> has not already been done. Makes it a lot easier to remove/replace
> whenever
> >> you need to get behind the gauges/controls, etc.
> >> Carl Stouffer
> >> '75 ex Palm Beach
> >> Tucson, AZ.
> >> Chuck Aulgur Reaction Arm Disc Brakes, Quadrabags, 3.70 LSD final drive,
> >> Lenzi knuckles/hubs, Dodge Truck 16" X 8" front wheels, Rear American
> >> Eagles,
> >> Solar battery charging. GMCSJ and GMCMI member
> >> GMCnet mailing list
> >> http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
> > Vern Crawford (and Lenore Langsdorf)
> > 155 JJ Lane
> > Center Point, TX 78010
> > (618) 203-8296 Vern's cell
> > (830) 928-5550 Lenore's cell
> > VernCrawford
> > LenoreLangsdorf
155 JJ Lane
VernCrawford
LenoreLangsdorf
modification.
warning lights.
Vern
> Vern:
> Mike
> Sent from my iPhone
> > Thanks Carl,
> late,
> force
> noisy
> > Vern
> >> Vern,
> >> removed,
> whenever
> >> Carl Stouffer
> >> '75 ex Palm Beach
> >> Tucson, AZ.
> >> Eagles,
> >> GMCnet mailing list
> > 155 JJ Lane
> > VernCrawford
> > LenoreLangsdorf
155 JJ Lane
VernCrawford
LenoreLangsdorf
