Jack, what is the voltage supposed to be?
12VDC? Must not be, as you already have 12v from
a battery you could substitute.
Regards,
Steve
> SNIP
> I removed the refrig. The Compressor is getting voltage but only for a
> split second and then the power supply shuts down and tries again a min or
> so later.
> I think either the power supply does not have enough juice to get the
> compressor running or the compressor is not working.
> SNIP
> Doyle Todd
> 1977 Transmode
> Harlingen Texas.... Paradise.
Regards,
Steve
> SNIP
> so later.
> SNIP
> Doyle Todd
> 1977 Transmode
