I am replacing my headliner as so many of you have done before. My problem
is the fit between the ceiling and the bath mod near the refrig and on the
other side between the ceiling and the dresser/closet mod. There doesn't
seem to be much room to slide the new panel into place. Just trying to
insert a small test piece is difficult to impossible unless it come at
those corners from the center and is pushed towards the outside wall, which
with the full size piece can't be done. I am using a panel of the same
dimensions as the original - or as close as possible using the old one as a
template.
So, has anyone else had this problem and if so what did you do to overcome
it and/or is there maybe a way to temp raise the roof in that area so I can
slide the panel in and then lower the roof on? Or any other ideas?
Really hate to cut the ceiling panel so short that I would need to install
a ceiling fill strip to hide the gap that would result.
Again, thanks in advance for all assistance.
Fay Curtis
'76 Glenbrook
Kneeland, CA
template.
Fay Curtis
'76 Glenbrook
Kneeland, CA
