GMC Motorhome Digest V1 #205
norman r. eby
20
Larry Nelson,
The annuciator light for the air bags is a small 3-connector thermal
relay plugged into a socket under the dash. Mine was staying on all of
the time so I disconnected it. I also disassembled the relay and found
out how it works. There is a bimetal strip wound with "resistance wire"
which causes the lamp circuit to open after a short time.
I have built a solid state version and may be able to install the
circuit in the same "can" as the original...ought to work forever or a
long, long time- whichever comes first. If anyone is interested I might
go into production as I could not find a new replacement locally. Could
probably build them for about $10.
Norm
Please don't quote the entire digest when replying. The resulting email
is too long and it bounces.
> Date: Sun, 28 Jun 1998 21:26:40 -0400
> From: "Norman R. Eby"
> To: gmcmotorhome
> Subject: [Fwd: GMC Motorhome Digest V1 #205]/Don and Margaret Miller
> Don & Margaret,
> Greetings from Norm & Carol Eby/Studley, Va. (That's near
> Mechanicsville, Va. which is a suburb of Richmond.)
> We have owned a 1976 Glenbrook for a little over a year now. Our GMC
> AC has the same low output as yours. I'm going to check for
> obstructions in the AC box under the hood first. I put my gauges on
> the AC lines and the pressures looked good.
> Let us know where you live. We belong to the "Tidewater Crabs" GMC
> club and have ralleyed with them a couple of times so far.
> Norm & Carol Eby
Patrick Flowers
Mailto:patri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
Please don't quote the entire digest. Thanks!
> Date: Sun, 28 Jun 1998 21:38:25 -0400
> Reply-To: neby
> To: gmcmotorhome
> Larry Nelson,
> of the time so I disconnected it. I also disassembled the relay and
> found out how it works. There is a bimetal strip wound with
> "resistance wire" which causes the lamp circuit to open after a short
> time.
> a long, long time- whichever comes first. If anyone is interested I
> might go into production as I could not find a new replacement
> locally. Could probably build them for about $10.
> Norm
Patrick Flowers
Mailto:patri63
