Gauges
G&Rs66
Member
Jul 24, 2016
64
6
Hi all I thank all of you for your info that I read and I have learned a lot of things. I'm getting ready to install machnical gauges and was
wondering where the best place for the sending unit for the transmission temp would go or where others have put them?
1978 Transmode
1966 GTO{frame off restor}
Wautoma, Wi (About 35 miles west of Oshkosh, Wi)
Gene Don't Do Facebook
but Ronny does
Get one of these. It has a port for a temperature sender.
http://appliedgmc.com/prod.itml/icOid/1047
bdub
Gene,
This device is better than mechanical gages (although my Avion in the USA has both).
http://www.appliedgmc.com/prod.itml/icOid/1853
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Gene&Ronny Knueppel
Sent: Friday, July 14, 2017 8:53 AM
Subject: [GMCnet] Gauges
gauges and was
1978 Transmode
but Ronny does
> Here is what I did. This pic and the next two tell my story. Been this way for 13 yrs. No issues.
> http://www.gmcmhphotos.com/photos/transmission-install/p3851.html
> JWID
OH, BTW, I put the sensor in the front right corner of the pan because that is where the most clearance is. Can't pick just any spot. The sensor
will interfere with the valve body, so look carefully before you drill.
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Larry,
Where did you purchase the adapter from or whom, and what part# would I use?
Thanks
JR Wright
>> JWID
> Larry
> Menomonie, WI.
Keep in mind that what is important is to know the temp of the fluid being
pumped into the trans.
Should you want to monitor the out temp, it will be very high when a load
is placed.
> > JWID
> Larry
> Menomonie, WI.
> Larry,
> Thanks
> JR Wright
> >> JWID
> > sensor
> > Larry
> > Menomonie, WI.
Oh Geese John....that was 10 or so years ago that I did that. IIRC the adaptors came with the gauge. I just made what came with it work. Added the
fiber washers and gooed it up with silicon. Also had to saw off the end of the brass piece inside of the pan so the temp probe would be surrounded by
fluid. I could not find a Trans temp gauge that would match what I had and was reasonably priced, so I used a Water Temp gauge. With my new dash, I
have now used a "Oil Temp" gauge that matches the SW gauges I put in. Just what I did.
Larry
Menomonie, WI.
I like the Ragusa pan and the Digi panel. I have ran both in the past.
Now, with my newer coach I'm running the Ragusa pan. I like it because it is thicker material, and doesn't leak like my stock pan did. Also holds more
tranny fluid.
But, I'm also going to install the Digi panel when I get a chance.
Scott.
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater.
Houston, Texas
Scott, I have both and glad that I do, although the panel just stopped
working the other day. I'll have to investigate that as it has worked
without fail since installing several years ago.
On Fri, Jul 14, 2017 at 12:29 PM, Scott Nutter
> tranny fluid.
> Scott.
> Scott Nutter
> Houston, Texas
William S. Schurman
box 772806
Steamboat Springs, CO
80477
1978 Palm Beach
TZE168V100258
I think I have the manual and schematic for the Digi panel if you need a copy to troubleshoot.
Scott Nutter
Houston, Texas
I would like s copy
> Scott Nutter
> Houston, Texas
Alternator Protection Cable
Gene,
I will go to storage today where I keep my gmc and parts. And look for the manual and schematic.
I will get back to you later today, scott
Scott Nutter
Houston, Texas
Tanks maybe bdub has it. ? I need the schematic
> Gene,
> Scott Nutter
> Houston, Texas
You can find the Digi-Panel information at:
http://www.digi-panel.com
The various files are at the top of the page.
JR Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 30’ Stretch
Michigan
> I would like s copy
>> Scott Nutter
>> Houston, Texas
Nope, don't look like I have it. Surprise!
Pass it along so I can host it.
http://bdub.net/manuals/
bdub
Sent: Saturday, July 15, 2017 8:52 AM
No schematic
> bdub
> From: Gmclist On Behalf Of gene Fisher
The DigiPanel is now owned by Jim K as the original builder got out of the business. The schematic may be propriety, but you can ask him if he will release it.
JR Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
Michigan
> bdub
Gene,
I have a paper copy of the manual (4 pages) in the mail to you. Unfortunately there is no detailed schematic.but it does have the wiring diagram.
It is pretty much the same as on the Digi panel web site.
I hope it's what you need.
Scott
Scott Nutter
Houston, Texas
