Fuel question
roger hannon
12
As long as you guys are talking fuel I have a question. I am a Newbie picking up my “new” 75 Tuesday afternoon in Detroit. I will be traveling to Minnesota to visit my mother for a few hours and on to Colorado. The tanks are full. What grade of fuel should I be using? It looks like it will be beyond chilly for this trip so I am planning on some short stays in truck stops so the engine does not get awful cold before restarting. Any suggestions are appreciated. If all goes well we plan to head to AZ the end of December and give it a through going over. For now I am just wanting to get back to Colorado unscathed. Probably replug and rewire if necessary in CO.
Happy Trails,
Roger
>> I am about to drop the tanks and re hose and refresh the fuel system. This is why I'm asking, so I can take the time to fix this too while
>> they're down. or try to, any way.
>> if, in a new system, it worked that the main and aux tanks read exactly the same until less than a 1/4 tank, and mine are reading differently at
>> 1/2 to 3/4, then I can assume there is something amiss with my system.
>> if this (different readings) cannot be because there are different amounts of fuel in the different tanks, because they self level, then I will
>> again assume there is something amiss with my system.
>> are my assumptions correct?
>> thanks again.
> If no one has messed with the fill plumbing or the venting, on level ground, the tanks will stay at the same level until they drop below the fill
> inlet level. Then the pump will pull from whatever tank is selected until it is empty, or you select the other tank. The point where they stop
> "self-leveling" is around 6 gallons in each tank.
> If your system is stock, your assumptions are correct. Most likely what is "amiss" in your system is a float or two, or a potentiometer or two, or
> connections, or some combination of those.
> 73 23' Sequoia 4 Sale
> 73 23' CanyonLands Parts Unit 4 Sale
> Upper Alabama
> "Highest price does not guarantee highest quality."
I have always used the low octane (87 or even 85) and had no problems. I
don't know how cold temperatures might change that but I would think lower
would be better there too.
> CO.
> Happy Trails,
> Roger
> >> thanks again.
> > Upper Alabama
Just use the cheapest you can fine, Roger. It won't matter a bit.
Welcome to the family. What part of CO do you live? There's some from there already down at Quartzite. The CA contingent will be there next month.
bdub
76 Palm Beach in Central Texas
www.bdub.net/GMCLinks.html
https://www.facebook.com/groups/classicgmcmotorhomes/
https://www.facebook.com/groups/gmcmm/
Sent: Monday, December 12, 2016 4:49 PM
It's going to be near zero this week in MN and the roads are slippery.
Make sure your heater works and hang a curtain behind the drivers seat or you will freeze your ass off.
The upside is vapor lock should be minimal.
Sent: Monday, December 12, 2016 4:57:26 PM
Subject: Re: [GMCnet] Fuel question
bdub
www.bdub.net/GMCLinks.htmlhttp://www.bdub.net/GMCLinks.html
Ethanol free and hope that the fuel in the tanks now is also ethanol free or you may be in for some clogged filters. Hopefully the PO has upgraded the fuel system to accept the 10% crap but I would not count on it.
> Happy Trails,
> Roger
>>> thanks again.
>> Upper Alabama
Thanks a bunch.
Roger
75 Avion courtesy of Tims family (GreatLakers) I have never been treated so well before purchasing an RV. Tim would be very proud and we intend to continue that tradition in caring for his 75.
> bdub
> From: GmclistOn Behalf Of Roger Hannon
We live in Parker.
BTW, I have a friend we RV with that wants a twin bed dry bath if anyone has one for sale.
Thanks,
Roger
75 Avion
> bdub
Thanks for the thoughts about the ethanol as I was thinking I would stop right after picking the 75 up and load up the tank with deicer and try and dry out any water that may be in the tanks. I think that stuff is either alcohol or may be ethanol based. I think the fuel is fairly fresh as Tim passed away recently and it was winterized prior to his passing. The family has worked hard to make sure it is road worthy as they know the trip I have ahead of me.
Thanks,
Roger
75
bdub
www.bdub.net/GMCLinks.htmlhttp://www.bdub.net/GMCLinks.html http://www.bdub.net/GMCLinks.html
I plan on coming up from Chicago on I-90 only to LaCrosse and going into Winona on Hwy 61 to see my mother. Pop back up onto I-90 in the early afternoon on Wednesday and head for DesMoine for a truck stop layover before heading home on Thursday morning early. The family of the PO indicated the engine was not starting with one pump and they were having it checked today. My hope is it just needs running. If it needs carb work I hope that waits until I get home to Parker, Colorado. That will be another question for another time. Maybe even Friday if I get back OK but recognize I do indeed have a problem. Altitude may be an issue too as I come home.
Roger 75 Avion
bdub
Not much fuel “deicer” is sold anymore. The ethanol that they add to fuel is the same thing. Ethyl alcohol is ethanol. You’l have a hard time finding non-ethanol added gasoline. So when you put in most gasoline it will absorb any water in the tank (unless you have an inch or so of water :) ). I wouldn’t worry about having any water in the fuel as they probably have been getting ethanol / gasoline fuel.
When you get back to Parker you should consider joining the GMC Mountinaires which is a local GMC club. Lot of members that own GMC are around you.
Frederick, CO
> Thanks,
> Roger
> 75
> From: Gmclist on behalf of Billy Massey
> To: gmclist
> bdub
Awesome, thanks for the tip. Please forward the website if you have it handy.
Sent from my iPhone
> Emery Stora
> 77 Kingsley
> Frederick, CO
>> Thanks,
>> Roger
>> 75
>> To: gmclist
>> bdub
