As long as you guys are talking fuel I have a question. I am a Newbie picking up my “new” 75 Tuesday afternoon in Detroit. I will be traveling to Minnesota to visit my mother for a few hours and on to Colorado. The tanks are full. What grade of fuel should I be using? It looks like it will be beyond chilly for this trip so I am planning on some short stays in truck stops so the engine does not get awful cold before restarting. Any suggestions are appreciated. If all goes well we plan to head to AZ the end of December and give it a through going over. For now I am just wanting to get back to Colorado unscathed. Probably replug and rewire if necessary in CO.
Happy Trails,
Roger
>> I am about to drop the tanks and re hose and refresh the fuel system. This is why I'm asking, so I can take the time to fix this too while
>> they're down. or try to, any way.
>> if, in a new system, it worked that the main and aux tanks read exactly the same until less than a 1/4 tank, and mine are reading differently at
>> 1/2 to 3/4, then I can assume there is something amiss with my system.
>> if this (different readings) cannot be because there are different amounts of fuel in the different tanks, because they self level, then I will
>> again assume there is something amiss with my system.
>> are my assumptions correct?
>> thanks again.
> If no one has messed with the fill plumbing or the venting, on level ground, the tanks will stay at the same level until they drop below the fill
> inlet level. Then the pump will pull from whatever tank is selected until it is empty, or you select the other tank. The point where they stop
> "self-leveling" is around 6 gallons in each tank.
> If your system is stock, your assumptions are correct. Most likely what is "amiss" in your system is a float or two, or a potentiometer or two, or
> connections, or some combination of those.
> 73 23' Sequoia 4 Sale
> 73 23' CanyonLands Parts Unit 4 Sale
> Upper Alabama
> "Highest price does not guarantee highest quality."
Happy Trails,
Roger
>> thanks again.
> Upper Alabama
