Front wheel spacers
6cuda61
418
The spacers from Applied are going to be your only option unless you have something custom made.(washers behind the wheels will lead to broken studs,
not safe!!)
Calipers, as far as i know, should be the same but again they may have been changed to something else by the PO.
Rich Mondor,
Brockville, ON
77 Hughes 2600
I am not familiar with your rims, but the 80mm usually fit under a 16.5" rim.
the way to easily tell if they are the 80mm calipers is by the brake hose, it uses a banjo bolt rather then the hose screw directly into the caliper.
so look at the photos and compare the hose itself.
https://www.gmcmotorhome.com/commodore/front_brake/index.html
Jon Roche
75 palm beach
St. Cloud, MN
Sir, the spacers from Applied are special made for hub centered wheels. Since the Weld wheels are stud centered a standard spacer will work. This is
the kind I use on my Weld wheels. 8x6.5 with 9/16 x 18 studs. I use 2” spacers.
https://wheeladaptersusa.com/collections/8-lug-wheel-spacers-adapters/products/2-pcs-2-inch-8x6-5-to-8x6-5-wheel-spacers-adapters-9-16-stud-dodge-ford
> I recently purchased a 77 Kingsley with the original steel 16.5" wheels. I have a set of Weld Racing 16.5" wheels that i got off a 73 that I had
> also purchased. I'm installing the Weld Racing on to the 77 which is the one I plan on keeping. I have a tire changer and plenty of tools and jacks
> to do the job. Ive never worked on any vehicle this large and those damn wheels are heavy. Anyhow the rears have been swapped. When I removed the
> Weld Racing wheels off the 73, the PO had some washers as spacers on the lugs. I thought "UH OH... nothing is as simple as it seems".
> When installing the wheels on the 77, I reused the washer/spacers assuming it would work as it did on the 73. but of course "nothing is as simple
> as it seems" and the wheels hit against the calipers. I havent compared the calipers to see if they are different, but obviously something is
> different.
> Does anyone know if the calipers changed from 73 to 77? Ive read about some upgrades to 80mm, could that be what I have on the 77? How to find
> out?
> Also whats spacers can I install. I did a quick search and couldn't find spacers 8 x 5.5".... about 1/4" should clear. I saw the ones from Apllied
> But those are 2" and more than Id like to spend.
> Any suggestions?
> Thanks in Advance
C. Boyd
76 Crestmont
East Tennessee
The 80 mm calipers have a "bump" sticking out of one outer side. That bump
touches Alcoa and other 16" wheels until ground down to match the rest of
the housing. I don't know whether it conflicts with OEM 16.5" wheels, but
perhaps that's what's interfering with your Weld wheels?
On Tue, Aug 25, 2020 at 7:52 AM Charles Boyd via Gmclist <
> is
> spacers.
> simple
> > different.
> > out?
> > Any suggestions?
> > Thanks in Advance
> C. Boyd
> 76 Crestmont
> East Tennessee
My apologies sir, it won’t happen again.
> Thanks Boyd, But the GMC uses 8 X 5.5", not 8 X 6.5".
C. Boyd
76 Crestmont
East Tennessee
Our spacers are made to fit our hub.
The one that Chuck posted will not wor as the hub is mot the correct size.
Remember our Kits are made for our coach,
On Tue, Aug 25, 2020 at 8:41 AM Charles Boyd via Gmclist <
> C. Boyd
> 76 Crestmont
> East Tennessee
http://www.gmcrvparts.com
Dang it Jim, I wish you had told me that 10 years ago when I used them to mount my Weld wheels I got from Terry Taylor. To late to take them off
now.
http://www.gmcmhphotos.com/photos/crestmont/p35851-back-on-the-ground.html
http://www.gmcmhphotos.com/photos/crestmont/p35782-right-side-on.html
> > C. Boyd
> > 76 Crestmont
> > East Tennessee
> Jim Kanomata
> jimk
> 1-800-752-7502
C. Boyd
76 Crestmont
East Tennessee
All of you can gain some information by spending time going over our parts
and kit.
We have everything and most kits and we spend lot of time on the phone with
people.
We just released a Electric remote door Lock kit.
On Tue, Aug 25, 2020 at 7:44 PM Charles Boyd via Gmclist <
> now.
> size.
> > > C. Boyd
> > > 76 Crestmont
> > > East Tennessee
> > > GMCnet mailing list
> > Jim Kanomata
> > jimk
> > 1-800-752-7502
> C. Boyd
> 76 Crestmont
> East Tennessee
I have a set of Weld 16.5" wheels (thought they were Alcoa's) on my stock 73. Fit great.
Tried them on my 75 with a Manny 1-ton and they hit on the caliper.
Bob Broadwell
75 Eleganza II-Rebuilt performance engine, Manny trans, Manny 1-ton front end, 73 23ft with a side bath getting some updates-both living in Las Vegas
Do you have 6 or 7 wheels and what is the asking price.
JR Wright
Michigan
> Bob Broadwell
They are listed over in the swapmeet
Bob
Bob Broadwell
These are what I put on mine to increase the track width closer to the rear wheel distance, quicken the steering response in slow speed maneuvering,
and give the front tires a wider stance during cornering. They are almost $40. more now than when I bought mine. I did not want the 2 inch thick
ones,thought it might stress out the 1973 lugs, but other owners have used them with no problems that I recall reading about. I might be the only
GMCer running the 1.5 inch type. Any spacers will increase the leverage of the tire over the suspension system, and indeed I needed to tweak up the
left torsion bar and replace the right one that had already weakened and twisted over many years.
https://www.ebay.com/itm/2-pc-8-Lug-6-5-To-8-x-6-5-Wheel-Adapters-Spacers-9-16-Studs-1-5-Thick/260656291080?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Here are the 2 inch ones:
https://www.ebay.com/itm/2-USA-MADE-8-Lug-6-5-To-8-x-6-5-Wheel-Adapters-Spacers-2-W-Studs-lug-nuts/251333324604?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Jim probably has a better deal, I haven't checked, but he will definitely have the best warranty responsibility and representation on any product he
sells. I haven't had any problems I can relate to the set that I got.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
I've never heard of an 8 on 5-1/2" bolt pattern.
Jim Hupy used to (or maybe still does) make spacers (maybe 1'4" or 3/8' thick) to alleviate clearance problems when using steel 16" wheels on the
front. Maybe they would work for this application too.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
I did, but no longer do. Why? Well, my machinist friend who had the big
lathe, his wife died. He became extremely depressed and in spite of his
friends best efforts, turned into a drunken fool. Where he remains today.
I know how he felt (feels) but some very good gmc friends and a
fantastic woman intervened and wouldn't let me kill my self with Jack
Daniels and blues music played way too loud. So I don't have that contact
at my disposal any longer. I do have the services available to me of an
extremely competent machinist, but his custom hourly rate is probitive for
ones and twos of anything. Sorry.
On Wed, Aug 26, 2020, 8:17 PM Carl Stouffer via Gmclist <
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Eagles,
Think it was Jim Bounds, correct me if I’m wrong, did a video saying these Motorhomes weren’t meant or designed to use wheel spacers and
recommends against them
