Frig propane vent
Billygoat
648
122
43
Kansas City Missouri
Sorry for all the post guys. I’m in the process of resealing and painting my roof and have also run into a apparent propane fridge vent even though I have a all electric fridge. Would you guys cover it up with sheet metal or would you maintain it? My plan is to look at solar power panels for power for the fridge. I could just clean up the hood and put it back down. I’ve got 1/4” wire over the hood opening to prevent mice getting in. What would you guys do?
I'm going through the same thing right now (converted propane to DC fridge). Removed fridge roof vent, about to rivet-down a sheet of aluminum to create more space for solar panels.
Kendra,
Does the removed heat exit to the front? It seems that a ventilated rear cabinet would preserve the efficiency of the unit. I've never looked at one of the DC units.
Dometic DMC4101 installation instructions don't specify a requirement for back or top ventilation. Top and sides are smooth, and the back is mostly smooth with a tiny set of louvers near the bottom. I might cover-up the GMC's exterior side vent as well. Here's the DMC4101 back side:
I'm not a fan of Dometic's sometimes ambiguous instructions. The link you shared has information in the troubleshooting section that's not worked out in the installation. It says the outside for the refrigerator should not be touching the walls of the cabinet enclosure, and as you say, it does not mention ventilation.
A refrigerator is a heat pump. The heat you're pulling from the inside of the refrigerator had to go somewhere and without any exterior vents it's all going to the inside. Maybe that's not a concern if the AC is cranked up to compensate, but it should be considered when designing the enclosure.
Here's AI's take on the situation.
To calculate the heat load inside your RV cabinet, you must look at how much of those 532.3 BTU/hr are trapped as waste heat.
Because the Dometic DMC4101 is a front-venting refrigerator, it is highly efficient at pushing heat forward into the living space. However, it still radiates a small portion of electrical waste heat directly into the sealed rear cabinet enclosure.
1. Calculate Active Heat Load (10% Radiated)
Compressor refrigerators vent about 90% of their heat out the front grille. The remaining 10% radiates from the compressor housing and condenser loops into the back cabinet:
\(532.3\text{\ BTU/hr}\times 0.10=\mathbf{53.2}\text{\ BTU/hr}\)
2. Calculate Standby / Idle Heat Load
Once the refrigerator reaches its target temperature, the compressor runs roughly 35% to 50% of the time (a 50% duty cycle is typical in warm weather):
\(53.2\text{\ BTU/hr}\times 0.50=\mathbf{26.6}\text{\ BTU/hr\ (Average\ Cycle\ Heat\ Load)}\)
3. Calculate Maximum Startup Heat Load (100% Load)
If the refrigerator is working hard to cool down groceries on a hot day, or during an active defrost cycle, the compressor runs at 100% capacity continuously:
\(532.3\text{\ BTU/hr}\times 0.10=\mathbf{53.2}\text{\ BTU/hr\ (Continuous\ Peak\ Load)}\)
✅ Final Answer
The continuous heat load inside your RV cabinet will fluctuate between 26.6 BTU/hr during normal cycling and a maximum peak of 53.2 BTU/hr under heavy usage.
Graph image
Cabinet Ventilation Recommendation
To prevent this heat from degrading your refrigerator's efficiency, ensure you maintain the factory-required cut-out clearance of 59.9" H x 24" W x 24" D. If the cabinet is completely unventilated and tightly sealed at the top, trapping even 53 BTU/hr can cause the compressor to run longer and draw more battery power.
Me again: Note that the above calculations are for the waste heat inside the enclosure, the other 90% waste heat is warming up the coach interior.
The Dometic 12v fridge has performed well for two years with the original exterior vents in place. I'm definitely going to block/cover the previous propane roof vent location - I need that for more solar.
Next time I'm dry-camping with high temperatures, I'll take heat gun measurements around the 12v fridge.
My original question of "Where does the heat go?" still applies Kendra. I look forward to your temp measurements.
