Flush mount black tank vent?
6cuda61
418
So maybe a stupid question as i have the time to ask it.... does anyone make a flush mount RV sewer vent?
When Hughes built these coaches i'm not sure if they ever thought 2 AC units would ever be put on the roof....anyways to make a long story short i
have a second AC i could put on but the black tank vent is basically in the way. :cry: Some might say...just move it...and the mechanic in me says
sure thing....but none of these units have fiberglass bathrooms like the GM models do and they ran the pipe from the tank up the hallway side corner
behind the toilet hidden behind a "box".
In order to move it i have to also move "the box" and my cabinet maker wife said "leave it alone or your going to open up a whole can of worms".....so
the only other choice other than redoing the whole bathroom, if i want to add the AC is a flush mount black tank vent that will be just under the none
fastened part of the AC unit [the part that is held up off the roof].
So what do you think.....does one exist? Bad idea as it is possible the AC might suck in fumes from the tank vent? Options? I know i can not put the
second AC on altogether and install some really expensive vents instead [i want one to be able to run in reverse].
Rich Mondor,
Brockville, ON
77 Hughes 2600
Rich
Some have installed the rear AC unit reverse direction - would that give you the clearance you need.
Putting the AC unit on "backwards" apparently has no affect on its performance.
Dennis
> worms".....so the only other choice other than redoing the whole bathroom, if i want to add the AC is a flush mount black tank vent that will be
> just under the none fastened part of the AC unit [the part that is held up off the roof].
> the second AC on altogether and install some really expensive vents instead [i want one to be able to run in reverse].
Dennis S
73 Painted Desert 230
Memphis TN Metro
This is true when more clearance is needed. When your parked the AC unit doesn’t know which way it is facing.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
Michigan
> Rich
> Dennis
> Dennis S
> Memphis TN Metro
Problem wit a flush mounted sewer vent is when snow and heavy rain will
drain down the vent and possibly fill your sewer tank.
On Sun, May 24, 2020 at 2:09 PM John Wright via Gmclist <
> J.R. Wright
> GMC Great Laker MHC
> GMCGL Tech Editor
> GMCMI
> Michigan
> > On May 24, 2020, at 4:48 PM, Dennis Sexton via Gmclist <
> > Rich
> performance.
> > Dennis
> corner
> will be
> up off the roof].
> > Dennis S
> > Memphis TN Metro
http://www.gmcrvparts.com
Thats actually the problem...proper way its to long [low profile unit] so backwards mounting is the only option, which i actually planned on...but
what i didnt plan on was the Black tank vent being 12" from the roof vent and about 4" off centerline to the right...I'm about 10" short of the
clearance i need. :x
Rich Mondor,
Brockville, ON
77 Hughes 2600
JimK,
I hope I'm not being a wise-ass here, but a 30 gallon tank (about as small as we GMCers have) should hold about 3,920 inches of rainfall entering a
1 1/2" pipe opening. That's 326 feet of rain. Unless the tank is already brim-full, I wouldn't worry about it. ;)
HTH
rick Staples
Does the A/C unit bring in outside "fresh" air when running?
If so you might not want a black tank vent in close proximity to it... the air might be just be "too fresh"... if you get my drift...
Bruce Hislop
ON Canada
Not sure, i would have to see if it does.
And that "fresh air" is what im worried about.....lol.
Rich Mondor,
Brockville, ON
77 Hughes 2600
I think im in a pickle and am going to have to just shelve the second a/c till i figure out the vent and bathroom deal.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Rich,
I'm not sure where you are planning on traveling to in the near future, but we have only one A/C and have no problems staying cool in southern Ontario
and great lakes states of the USA.
Bruce Hislop
ON Canada
We will be fine here in the Eastern end of Ontario but we have planned a trip to prairies for 3 weeks and it gets damn hot out in the open there.....
Plus i'm being cheap....lol....as i have it and dont want to buy 2 new roof vents. :blush:
> Rich,
> Ontario and great lakes states of the USA.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Rich
I once put a microwave into the top shelf of the cabinet opposite the bathroom. I found that the vent pipe from below wanted to go through the microwave. I cut the vent pipe below the microwave and then used radiator hoses with bends to vent around the microwave and then up to the existing roof vent. This worked very well for me.
It will work just fine with bends in the pipe.
Frederick, CO
> I think I'm in a pickle and am going to have to just shelve the second a/c till i figure out the vent and bathroom deal.
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
If you can get to that vent inside the coach you might be able to install an Air Admittance Valve and eliminate the roof vent. I'm not a big fan of
these valves but they are code compliant. Just an idea, Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
Assuming (yeah, I know) that you would probably only need the rear A/C unit when you were stopped (for the night?), one of those "weather vane" type venturi extractors on a maybe extended vent pipe could serve to get the "fumes" away from the A/C. I'm not even sure that our coach A/C units use outside air, so no real worry!
D C "Mac" Macdonald
Amateur Radio K2GKK
Since 30 November '53
USAF and FAA, Retired
Member GMCMI & Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
Sent: Monday, May 25, 2020 13:46
Cc: Hal StClair
Subject: Re: [GMCnet] Flush mount black tank vent?
1977 Royale 101348,
Rio Rancho, NM
Richard,
you are correct, however the rv manufactures do not want it to happen and
also easy to seal around the pipe at a higher level.
On Mon, May 25, 2020 at 8:48 AM Emery Stora via Gmclist <
> Rich
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > On May 25, 2020, at 8:22 AM, 6cuda6--- via Gmclist <
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
I was going to suggest an AAV, but I see Hal already beat me to it.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Air admittance valves are code compliant for most residential construction codes, but I'm not sure about installation in an RV, particularly on a
black tank vent. A residential toilet has its own built in water seal that prevents sewer gases from rising through the toilet, an RV toilet does
not. How an AAV would play with a ventless and trap-less toilet, I do not know, but it'd be a good idea to do your homework before cutting and
removing the existing vent.
Emery's solution of using radiator hose and hose clamps seems simplest and least likely to cause a stinky gotchya.
While on the subject of venting and traps, Hepvo waterless traps should replace P-traps in all RVs at the first opportunity. Easy to install, frees
up some room under the sinks, no need to winterize and gets rid of the tiny black flies that use the drains' trap water as a watering hole.
Richard
'77 Birchaven TZE...777;
‘76 Edgemonte
The vent pipe doesn’t care if it runs horizontal. Why not reroute the pipe horizontally along the top edge of the bathroom wall and have your wife build a cover to hide it.
The AAV would be a poor choice IMO because it is basically a 1-way valve, letting air into the system. The problem is they won’t let air out and could conceivably allow the Ptrap contents and tank gasses to get blown into the coach should something pressurize the holding tank.
Les Burt
Montreal
'75 Eleganza 26'
> Richard
> ‘76 Edgemonte
I agree with what Les said. An AAV is a great idea IFF there's another vent for the system. I seem to recall that even in a house, if you have a
septic system like some of us do, you need at least one actual unrestricted vent to atmosphere to prevent possible pressure build up. In an RV, I
think it's good to have at least 2 vents on different side of the tank to ensure one of them is always above the liquid level. Still, I plan to
replace the vent beside the refrigerator with an AAV some day, as it enters the tank at the same point as the rear vent (GMC wet-bath coach) does, and
so is superfluous for tank venting. (It's just here to be sure the water seal is not sucked out of the sink P-trap, as code requires if said trap is
over 4' from the main stack/vent.)
Also, some have questioned the proximity of a vent to the roof A/C. I know my 2 ancient Duo-Therms don't have any connection to draw in or exhaust
outside air, and I suspect most roof A/Cs are the same, but I'm not an expert on newer models. Even without a direct air intake, many roof A/Cs
aren't sealed all that well, so odor could be an issue.
Finally, in my previous comment about rain into an open pipe, I should have specified that I assumed that no water would be funneled off the roof into
the vent. As JimK rightly pointed out, you want the pipe to "stand proud" (as the Brits would say) from the roof for 1/4" or so to properly seal it,
and prevent funneling.
My .02, HTH
Rick Staples
Yeah, I guess an air admittance valve would be a bad idea if it was on the only vent line. My GMC finished coach has two vents to roof. I have no
idea what Hughes did.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
