Flush mount black tank vent?
Hughes has a vent for both sinks and one for the tank.
> Yeah, I guess an air admittance valve would be a bad idea if it was on the only vent line. My GMC finished coach has two vents to roof. I have
> no idea what Hughes did.
Rich Mondor,
Brockville, ON
77 Hughes 2600
If it's a single tank you should be fine with the valve.
Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
If you go with the HEPVO valves, you can eliminate all but one of the black tank vents, not sure how many you have, but I have three and will be
eliminating 2 of them... once I get to that project.
1973 GMC 26' Glacier - Unknown Mileage - Has a new switch pitch transmission with Powerdrive
One direct to tank and 2 that go to the sinks
Rich Mondor,
Brockville, ON
77 Hughes 2600
How about the marine side? What do they do? Would something like a marine fuel tank vent or something work?
I dont do boats over 22 feet, not sail powered and not less than 2 hulls....lol.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Rich,
The codes for fuel tank vents are completely different. RV codes are minor revisions of BOCA.
I used an AAV on my bus conversion and something inside failed. I replaced it with a more robust model and had the same result. I am not sure the
reason for either failure BUT I had to do a work around to get rid of the odor.
Just my experience.
Good luck on whatever path you take.
Melbo
> the reason for either failure BUT I had to do a work around to get rid of the odor.
> Just my experience.
> Melbo
Wouldn't have had that problem in an Eagle Bus :lol: :lol:
Hal
1977 Royale 101348,
Rio Rancho, NM
