Some time back I noted that my fan shroud did not extend back over the fan
blades. There were a couple of replys that I may be missing some shroud.
Some one else has pointed out that many vehicles have a spacer between the
water pump and fan to extend the fan forward closer to the radiator. On my
'75 PB the fan clutch is bolted directly to the pulleys with minimal space.
My shroud doesn't look like it's been butchered so I'm wondering if there
is supposed to be a spacer that has disappeared over the years.
Surely somebody has been this path before so let me hear from you. As is
I'll probably try to locate a two to three inch spacer. This will put the
fan and shroud in about the right relationship and improve cooling in town.
Next problem: while changing the belts I found that the slotted piece
which adjusts tension on the alternator was broken into several pieces. I
don't know how it was holding tension but it can't go back in. Autozone
was no help but since it was late Saturday I didn't look farther. Is this a
stock item somewhere or do I need to make a new one? Will check NAPA then
junk yards if no one knows of a sure source.
The good news is the AC hoses are all connected and the vacuum pump is
running.
It's down to 700 microns as I write this. Assuming every thing proves tight
and there are no other random failures I'll have first cool in a couple of
days. (working for a living sure slows things down)
It's county fair this week, the wife wants to leave for NY on Friday and
the GMC is in pieces. Might have to skip sleeping this week.
Anyway any info or insight will be appreciated.
Enjoy
Dick
running.
Enjoy
Dick
