Ahhhhh... So the solid pin replacement strike doesn't change the OEM distance between the pin and the plate; it just compensates for the missing rubber. If you don't want to buy the replacement plate then you might need to move the OEM plate outboard.No, the bushing is inside the shell. If the steel shell is loose it’s because the rubber has rotted and collapsed.
Rick “common to all the original pins by this time” Denney
My door, in addition to the missing rubber, is held away from the latch by an overcurved bottom that I need to straighten out, and I've created a new post asking if there's any suggestions on how to do that.
