If you need more electrical power generation, perhaps you could consider this approach.
Since it can be either a turbocharger or a generator (think direct current alternator). We have massive big block engines with a massive amount of waste energy in our mufflers and tail pipes.
Maybe I should install this instead of an electric supercharger or maybe both.
If I install both, I could generate the electricity with an eTurbo to power and electric supercharger and get more electricity to charge the batteries simultaneously.
I could certainly accept 48vdc with my (2) Lithionics 51.2v, 150aH batteries and I can add a third one. I also am planning to install 48vdc to 12vdc converters to back up the 12vdc 1,000aH BattleBorn battery bank for 12vdc appliances and other users.
I could also install a 48vdc battery to 12vdc battery charger with appropriate ATS to select the charging source.
Direct current motors are also direct current generators.
This is a Borg Warner product.
Maybe going uphill it's a turbocharger and downhill it's a generator. Isn't that how railroad diesel electrics work?
Which our massive engines, it make more sense to check out products that are characterized as gasoline or diesel trucks. Aren't every other motorhome built on the chassis and drivetrain of a truck or bus.
Maybe I have to merge this thread with the other thread I have on electric superchargers.
