Door Lock
gary m
13
I am trying to find a part number for a replacement door lock cylinder for my 77 Royale. None of the parts houses around here can find one that
matches the one currently in it. Any assistance would be great.
77 Royale
455
Rear bath, SW Virginia
Tell em it's for a Kenworth
bdub
On Tue, Sep 24, 2019, 11:16 AM Gary M via Gmclist
> 77 Royale
Tumbler is a GM see if Jim B at Coop has them. if not we can supply.
On Tue, Sep 24, 2019 at 9:30 AM Billy Massey via Gmclist <
> bdub
> On Tue, Sep 24, 2019, 11:16 AM Gary M via Gmclist >
> for
> > 77 Royale
The latch mechanism is, as Billy says, a Kenworth but it takes a GM tumbler. Any good locksmith can assist you or you might check Applied GMC or other GMC shops.
Frederick CO
>> bdub
>> On Tue, Sep 24, 2019, 11:16 AM Gary M via Gmclist >>
>> for
>>> 77 Royale
I will let them know. I didn't want to have to crawl thru the window to get in while at Mansfield!
Thanks
77 Royale
455
> bdub
According to my records, I replaced the door latch with a "Peterbilt Door Latch #20-08229R" for $39.82. That was April 2007.
I bought it at this place which is off I75.
Reefer Peterbilt
2645 Auburn Road
Auburn Hills, MI 48326
Tel (248) 852-8300
Maybe Kenworth and Peterbilt parts are the same now?
> > bdub
> Reefer Peterbilt
> 2645 Auburn Road
> Tel (248) 852-8300
Seems that I posted this from an GMCNET account I forgot I had. Thanks LASTPASS.
Richard
SE Michigan
www.PalmBeachGMC.com
Learn to use the knowledge of people that know.
Reach out to Jim B at Coop as he is on top of that, or call me for
asssistace.
On Tue, Sep 24, 2019 at 10:29 AM RJW via Gmclist
> > > bdub
> > Reefer Peterbilt
> > 2645 Auburn Road
> > Tel (248) 852-8300
> LASTPASS.
> Richard
> 76 Palm Beach
> SE Michigan
If you just want the cylinder and not the latch, my 76 was a plain GM cylinder and I got it (in stock) from AutoZone with two new keys. It was cheap.
If you need to re-key it to match other locks in the coach, Just about any locksmith can do it in a matter of minutes.
The grooves down the side of the key changed by year. If you are re-keying it, then you need to match the new cylinder to your existing key when you
buy it.
That description entered into Google brings up a lot of photos of a
complete latch -- NOT a lock cylinder. And it apparently doesn't even
include a handle.
On Tue, Sep 24, 2019 at 1:23 PM 76 via Gmclist
> > bdub
> Reefer Peterbilt
> 2645 Auburn Road
> Tel (248) 852-8300
While we are on the subject of locks.......... What would cause the door not to lock when you psh the button down and close it? Usually I have to try
a few times before it actually locks the door.
K
1977 GMC Royale 403
Push the lock down, hold the outside door in the "Open" position while
slamming the door. Or better yet, close the door with keys in your hand,
and lock it with the key. Then, you never lock your keys inside, with you
on the outside. BTDT.
On Tue, Sep 24, 2019, 2:14 PM Kevin via Gmclist
> K
> 1977 GMC Royale 403
In the shaft from the interior lock button to the latch, there's a "barrel
nut" which adjusts the length of the shaft. Careful adjustment of that nut
is necessary. It can either allow the door to be slammed and locked with
the button down (and the keys locked inside). Or, it can be set to cause
the door to unlock when the door is slammed (reminding you to get your key
and lock the door from the outside). I don't (and don't want to) know
whether pulling the outside latch while closing the door will allow it to
lock.
On Tue, Sep 24, 2019 at 5:14 PM Kevin via Gmclist
> K
> 1977 GMC Royale 403
