another option is to use compressed air to push the water out of the water
lines. If the holding and hot water tank drains are open then the kitchen
and bath fixtures can be purged on both hot and cold circuits by blowing
through the outlet and alternating the controls for hot and cold. This will
purge the lines and the hot water tank. The holding tank can be drained by
opening the drain valve. The hot water tank can be drained as well. A
little antifreeze in the p traps and you're done.
I typically
1.open all available plumbing drains including the hot water and holding
tank drain and wait for the flow to turn to drips
2. set my air pressure regulator to a low pressure of about 25-30psi
3. close the LINE drains if any and leave the storage and heater drains open
4. close all of the plumbing fixtures
5. start from the furthest fixture from the tank which in my case is the
kitchen faucet and wrap a wet rag around the end of my air blow gun to form
a seal with the faucet outlet and blow air with the cold open at the faucet.
6. once I hear the sound of the air going into the lines change to a
constant pitch turn the cold off and open the hot and repeat.
7. close the kitchen faucet and open bath fixtures one at a time and purge
them the same way
8. Leave hot water and holding tank drains open, check that line drains are
closed.
I have not had a freeze failure using this method.
Sully
77 eleganza 2
seattle
On Mon, Oct 3, 2016 at 6:39 PM, David Davidson
wrote:
> Hi,
> The PO disconnected and drained every water line before the coach was
> stored. This will be my first winter. I'm not going to repeat that. I will
> use
> anti-freeze. I was told to add two valves and a line to isolate the hot
> water tank. Does any one have a picture of this? Also, I;ve just read on a
> post that the water heater drain value is on the bottom of the tank. In
> order to replace that old value, is there enough room to get in there with a
> wrench and back it out, or do you have the take the tank out?
> Tx
> David
