Yep, that's the TEK way for sure. 70/30 Eutectic solder only. EVERYTHING
SCRUPULOUSLY CLEANED. RESIN CORE or solid, but using resin flux on every
joint. SOLDERING IRONS SHARPENED AND PROPERLY TINNED. ALWAYS, ALWAYS
meticulously cleaned up with alcohol, post soldering. All loose ends short
clipped. It better look good, as well as be electrically and mechanically
sound. Been there, done that, still do.
Salem, Oregon
On Sun, Mar 29, 2020, 9:38 AM rallymaster--- via Gmclist <
> I was told to heat the objects to be soldered enough to melt the solder,
> which would then flow between the objects to join them. Remove heat, let
> the junction cool a bit, then on to the next. Never heat the solder and
> let it flow onto the objects.
> Ronc
> On Sun, 29 Mar 2020 06:48:40 -0600 Bruce Hislop via Gmclist
> > So for my morning reading with my coffee I googled "crimping vs
> > soldering wire terminals" to see if I could find some hard info on
> > this.
> > The top search result was from Monroe Engineering LLC Inc.
https://monroeengineering.com/blog/crimping-vs-soldering-cable-connectors
> -which-is-best/
https://monroeengineering.com/blog/crimping-vs-soldering-cable-connectors-which-is-best/
> > Third paragraph reads (after describing crimping):
> > "What Is Soldering?
> > Soldering, on the other hand, is a process that involves joining two
> > or more objects using heated metal known as solder. Unlike with
> > welding, the
> > objects -- which in this case is a cable and a connector -- is not
> > heated. Rather, soldering only heats up the filler metal. As the
> > filler metal, the
> > solder, heats up, it's applied between the wire and the connector.
> > Once it cools, the solder hardens, thus joining the cable to the
> > connector."
> > For the last 50 some years I've been heating the parts to be
> > soldered and thought I was pretty good at soldering... now I find
> > out I've been doing it
> > wrong! (sarcasm alert)
> > This company makes wiring harnesses and cable assemblies so I hope
> > they only crimp.
> > But again, I'm not an Engineer so I could be all wrong.
> > BTW, When I was doing a higher current connection, I would crimp the
> > connection as normal, but also solder were the end of the wire came
> > through the
> > terminal. I figured this gave me a seal to the exposed strands but
> > also did not have the solder wicking up the wire strands causing the
> > strain relief
> > issues. JWID.
> > Bruce Hislop
> > ON Canada
> > 77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI & ESC.1 ton front end
> > My Staff says I never listen to them, or something like that
> > .org/mailman/listinfo/
gmclist_list.gmcnet.org
