Charging the 13.6v and 51.6 volt Lithionics batteries became a challenge. The charging sources are:
Generator
Shore power
Alternator
Solar
This is about alternators.
The option is using the existing alternator or replacing it. The stock alternator with its internal regulator are not capable of charging LiPO4 batteries, so it must be replaced.
Using a dc to dc converter to charge two different voltage battery banks was not a reasonable solution. The massively increased battery storage capacity was another problem.
I looked at jim Bounds serpentine belt system, but you needed to use CVF's alternator and that did not work, so...
This is a double belt 6-rib system for the Olds 455. It includes a new relocated power steering pump (upper right), new water pump (above crank pulley), new alternator (upper left) and air conditioning compressor (lower left).
My 455 was running fine, although one cylinder's compression was low. Rather than put Jim Bound's motor in, I decided to concentrated on reducing parasitic loads on the 455 first.
Now that Cliff Golby had solved the dashboard ac air flow, I decided to replace the functioning air conditioning compressor with a 12v dc air conditioning compressor. Up to 35hp of parasitic load os then off the 455.
The compressor's position will be replaced by a Balmar XT-VT-170-K6 alternator and LiPO4 capable Balmar external alternator. It is a 170 amp alternator for the (2) Lithionics 13.6v batteries.
I am submitting a Balmar 96-48-60-K-6 48v alternator for the March's recommended alternator (60amp @ 48v). This also has a LiPO4 capable external regulator.
All of the battery, generator, alternator, BMS, components are Bluetooth capable and can be viewed through the Lithionics app for Apple Car Play and Android.
Ny drawing does not exactly match the March's Ultra Mid-Mount, but it was the only drawing I could work with.
AS you can see, this is a massive alternator capacity, nut we are dealing with a massive battery storage capacity.
WIth the much faster charging cycle of the Lithionics batteries, coupled with their ability to handle much greater charging current, it is likely that the 455 will not have to work much harder and of course, it will not have to be charged by the alternator very often.
What we can be certain of is that we pull into our parking spot for the evening or more, the massive storage battery capacity will be 100% charged.
When then parked, for however long, the batteries will be recharged, first by the solar panels, second by shore power (if available) and finally by Firman generator.
What are your thoughts?
Generator
Shore power
Alternator
Solar
