My first RV, an Open Road 10 1/2 foot pickup camper, had a 20 gallon
potable water tank, with a manually operated pump. Plumbing was dead
simple. Holding tank was outside the camper on the ground. Connected via a
flex hose. Easy to fix. Then came a tow behind. Battery operated water
pump, no city water connections. Simple, had a propane hot water heater and
a 25 gallon potable tank. A bit more complex, but still simple enough. Next
came a 25 foot chassis built motorhome on a Dodge Van Chassis. City water,
12 volt pump, propane hot water heater, holding tanks, 30 gallon potable
water tank, filled from either the city water or a separate hose. Pressure
operated switch worked sometimes, sometimes not. P.O.S. offshore made.
Would sometimes divert like it was supposed to and fill the potable tank,
sometimes it would pressurize the city water side, and leave the potable
tank empty. Tried a couple of times to fix it. Gave up and never used the
city water side after that. Decided right then to never use the city water
hookup on any RV that I owned. That decision has served me well for many
years. The battery pumps are as reliable as an anvil. No regrets.
On Sun, Aug 16, 2020, 1:17 PM Ken Henderson via Gmclist <
> Me too, Scott. I've been RVing, with intermittent hiatus periods, since
> '57. Never had a really serious leak inside any trailer nor motorhome.
> Maybe I'm just more cautious about watching and repairing plumbing than
> some. When I bought and gutted the GMC in '98, ALL the plumbing came out
> and was replaced, but I'm still using some of the original tubing and
> fittings.
> Ken H.
> On Sun, Aug 16, 2020 at 3:56 PM Scott Nutter via Gmclist <
> > I would fix the city water leak. I couldn’t operate without it. I only
> use
> > the 12volt pump while on the road or as a back up. But at the same time I
> > always check my plumbing and always use a pressure regulator. Just my
> > opinion and what works best for me.
> > Scott.
> > Scott Nutter
> > 1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21
> final
> > drive, Quad bags, tankless water heater, everything Lenzi. Alex Ferrera
> > installed MSD Atomic EFI
> > Houston, Texas
