Felpro makes a new gasket that is supposed to stop the problem that you are
having. I have rebuilt 455 before and never had a problem. Have to be very
meticulous in cleaning everything and putting it together.
>I have about 5000 miles on since doing heads, etc.
>No oil leaks for first while but now it is leaking. Not bad, but it's
>leaking. Seems it's leaking on the front of the engine and the oil then gets
>thrown about by the fan.
>Been chasing it today with the UV light, but it (the light) bit the dust, so
>stuck until tomorrow.
>The rubber seal on the intake gasket is our prime suspect and after talking
>to a few folks the consensus seems to be to throw the rubber gaskets away
>and use gasket goop instead during install.
>Any experiences/thought on the matter?
>TIA - Heinz
>TIA - Heinz
