brake lines
> just received the information from classic tubes. They have all of
> the original OEM specs for the GMC motorhome and have sets in stock
> from a previous customer that went out of business. The set consists
> of all lines from the master cylinder to the brakes including al
> fittings other than flexible hoses. Price for 1 set is $295.
> Committed to price of $250 for 10 sets at this time. Willing to
> negotiate if quantity is greater. Now is the price?
Thomas,
I'll take a set.
Patrick
Patrick Flowers
Mailto:patri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
Marcus,
Could have been! They did not have SS line when I left but it would be
a welcome improvement. I am very interested in this project and am
following it with high hopes. I have many customers not on the net that
could benifit from such a part. I thought I would call the company next
week to see if they had a wholesale pricing structure that I could pass
on to you.
The trans. lines would also be a great upgrade part, these are the kind
of things I want to pass on to the general GMC community!
Will get involved in the conversation if I find out anything
meaningfull.
Jim Bounds www.gmccoop.com
> I am defintely interested in a set for my current coach and would be
> interested in two more sets for my other transmodes if the price was in
> the 250 or less range. Do they have or could they make up the rubber
> hoses in the new teflon stainless arrangement? I may go visit them next
> week if you think that would be prudent. I think we could come up with
> something close to ten sets. I wonder if the customer was CLASCO?
> Jim, any input on this?
> Marcus
> > just received the information from classic tubes. They have all of the
> > original OEM specs for the GMC motorhome and have sets in stock from a
> > previous customer that went out of business. The set consists of all lines
> > from the master cylinder to the brakes including al fittings other than
> > flexible hoses. Price for 1 set is $295. Committed to price of $250 for 10
> > sets at this time. Willing to negotiate if quantity is greater. Now is the
> > price?
> > >just received a reply form Classic tube company after my inquiry. They
> > >already have the patterns for the GMC motorhome and will call today with
> > >more information and prices. Will keep everyone posted. How many people
> > >would be interested in a complete set if they are reasonable?
Dick,
The rear brake hose Golby has is a perfect fit, the only difference is
the center block is squared off as opposed to rounded and who really
cares! Actually, if you look at someones hoses, it is easy to see if
they have been replaced recently, squared blocks mean they are new!
Golby went through the expense of having those built, they are the
supplier to everyone, if it's square- it's a Golby. The only other unit
is offered by Cinnabar which has the rounded block.
> Golby also has the T hose.
> Paul Bartz
> > From: Gcbr [SMTP:Gcbr]
> > Sent: Friday, June 12, 1998 11:04 AM
> > Subject: Re: GMC: Brake Lines
> > In a message dated 98-06-12 00:45:52 EDT, you write:
> > ber 'T' hose going to each wheel is not available so I had to
> > substitute by purchasing a pair of 1/4" brake line T's and four hoses
> > to go
> > from the T's to the wheels. The NAPA part number on the bill for the
> > T's is #702 x 4. They cost $2.64 each. The NAPA part number for the
> > hoses is #36827 and the cost is $22.53 each. The total assembly looks
> > like the original except it comes out about two inches longer. The
> > 'T' blocks didn't
> > Dick
> > Gatway Motorhome has the "T" hose. I just bought 2 from them.
> > Take Care
> > Arch
Thomas
Put me on your list. Shipping to Arizona
Hermann
> 6/12/98
20:40
> Thomas:
> I just saw the price of $250.00 for a set of SS
Brake lines.
> I still want a set - Keep the negotations going!
> Any Idea of shipping costs to Kalamazoo?
> Don Martin
> 22727
DO YOU YAHOO!?
Get your free #yahoo.com address at http://mail.yahoo.com
The hose part numbers I posted earlier are in error. When I started putting
it together it didn't go together quite right.It turned out that the hoses
have a 7/16-20 thread while the brake fittings are 7/16-24. I assume that I
could have gone back and gotten the right thread but didn't pursue it. The
Golby price is about $48 per side which is near enough that it isn't worth
pursuing.
Dick
>I too am replacing brake lines. Just thought I would update where I am. Am
>only in rear at this time so don't have whole story but can answer some of
>the questions I've seen here.
>I found a set of double flare dies for use with a standard flaring tool at
>Car Quest. The total cost was about $7.00 for the 3/16 and 1/4 sizes. It's
>a two step flaring process but I haven't actually done it yet.
>The lines from the rear hubs to the rubber hose measure about 3/16 x 24".
>NAPA has 20" and 30" so I bought 30" and will cut them down to size so I
>don't have excess weight to vibrate. Their recomendation was to just use
>them as is and not worry about the excess.
>The rubber 'T' hose going to each wheel is not available so I had to
>substitute by purchasing a pair of 1/4" brakeline T's and four hoses to go
>from the T's to the wheels. The NAPA part number on the bill for thr T's is
>#702 x 4. They cost $2.64 each. The NAPA part number for the hoses is
>#36827 and the cost is $22.53 each. The total assembly looks like the
>original except it comes out about two inches longer. The 'T' blocks didn't
>have the thru hole for mounting so I soldered a piece of copper tubing to it
>for a mount. If this happens not to hold it will only cause a rattle. This
>took them quite a lot of searching to match the combination so I didn't want
>to press my luck by insisting on a T with a thru hole.
>The run from the front to the rear is quite a lot longer than available
>standard lengths so I purchased a 25' roll of 1/4" from NAPA. (About $17 +
>connectors) This should be enough for the front also.
>I'll also replace the front hoses and this should give me more confidence in
>the system.
>I hope what I've learned is of some help to someone.
>Those rear hoses were a tough one that completely stumped several parts guys.
>Dick
Please add me to your list for ss brake lines for the 26 footer
Hermann
6/12/98
> Thomas Warner:
> If the brake lines are as good as
the Parking
> LIghts
> Please add me to the list. Anyway add my name to your list. I
would
> like to buy as set.
> Don Martin
> dvm22727
I will compile the list of people that have asked for Stainless Steel
brakelines both for the 26' and the 23' by Friday and post it for additions
and subtractions if there are any mistakes. Am waiting now for other GMC
clubs to answer that I notified. The more we can get in one buy the better
price we will get.
Am also waiting for someone to verify the differences between the 26' and
the 23'. Is it only 3' shorter in the straight run to the back?
>Hermann
>6/12/98
>> Thomas Warner:
>the Parking
>> LIghts
>would
>> like to buy as set.
>> Don Martin
>> dvm22727
I assume that any 26' GMC as originally built accepts the same set of brake
lines? That theres no difference between the GM furnished models and those by
Coachman - the Royales, for example?
I'd like a set of the ss brake lines for my 1977 Royale. : )
What else is required for a complete "Brake line" replacement? I've seen
mentioned hoses and "T" sections?
I'm sure these questions have been answered but I must have missed them.
John
