Emery, I bet I’ve spent two hours trying to find those—in stores, online,
anywhere. Searching finds copper washers for flat bolt heads and banjo
bolts. I see flare gaskets, but those are sized for tubing flares and I’m
not sure they’ll fit.
If you know of something sized for M10x1.5 bleeder screws, I’m all ears.
Rick “thinking they’ll have to be replaced at every use” Denney
On Mon, Sep 16, 2019 at 1:25 PM Emery Stora via Gmclist <
> You should try using one of the small conical copper washers that go
> between the casting seat and the bleeder screw. It will deform to take up
> the imperfections in the casting to allow sealing.
> Emery Stora
> 77 Kingsley
> Frederick CO
> > On Sep 16, 2019, at 10:22 AM, Richard Denney via Gmclist <
> > Thanks all for the final reassurances. The feel is different but it’s
> easy
> > to get used to it. I’ll test emergency stoping once the pads are broken
> in.
> > Now, to that bleeder seep. The bleeder on one of the calipers is still
> > seeping enough to wet my finger, but not enough to drip. A new bleeder
> > screw didn’t resolve it, which I sort-of expected though for two bucks it
> > was an experiment worth trying. That also eliminated the possibility of
> > dirt in the bleeder seat.
> > Is replacing the caliper the only alternative? I’m thinking that’s all I
> > can do—the caliper side of the bleeder seat must be the problem. I bought
> > the brake/reaction-rod kit nearly two years ago, and it came with Centric
> > calipers, so I think I’ll get a replacement from NAPA, which seems to
> have
> > a better reputation among the commonly available choices.
> > Maybe when I have the wheels off again I’ll measure runout with my dial
> > indicator. Maybe not.
> > Rick “whose projects never seem to get finished” Denney
> > On Mon, Sep 16, 2019 at 11:50 AM Jim Kanomata via Gmclist <
> >> It is standard to have the longer stroke when one has the 6 disc system.
> >> Shops that have experience installing them will tell you that it works
> >> better after you run it in.
> >> We know lot about that system as we sell all type of system and
> personally
> >> use them on my coach.
> > '73 X-Glacier 230 "Jaws"
> > Northern Virginia
> > Offlist email: rick at rickdenney dot com
> > http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
Northern Virginia
> Emery Stora
> 77 Kingsley
> Frederick CO
> easy
> in.
> have
> personally
> > Northern Virginia
Northern Virginia
