Yes, the best method is to bench bleed the m.c. But, you can perform the
process on the coach just as easily. One trick I use is to fill the
reservoirs just using the bleeder pump. An assistant is handy for this.
Take the plate off the top of the m.c. and observe what happens when you
SLOWLY depress the brake pedal. If you see any air bubbles, it is possible
you might have a defective new master cylinder. You should only see an
eruption of fluid above the ports, no air bubbles at all.
Salem, Or
On Wed, Sep 11, 2019, 8:41 PM Richard Denney via Gmclist <
> Jim, do you think I messed myself up by not bench-bleeding the MC?
> Rick “who’ll do it if necessary” Denney
> On Wed, Sep 11, 2019 at 10:50 PM James Hupy via Gmclist <
> > That eliminates a huge source of soft pedal. If your system doesn't
> improve
> > with break-in, then, you probably DO have air trapped somewhere. I have
> had
> > a couple coaches that I fought for a while. Both had P-30 mc.
> > Jim Hupy
> > Salem, Oregon
> > On Wed, Sep 11, 2019, 7:35 PM Richard Denney via Gmclist <
> > > Jim,
> > > I’m using the stock master cylinder, recognizing that I must check the
> > > fluid level routinely, since the rear reservoirs won’t hold enough to
> > > accommodate full pad wear. But I wanted the smaller piston for higher
> > > pressure. I have the rear calipers with the parking brake adjusted
> > snugly,
> > > so there is no gap other than what is left by runout.
> > > The new MC has the same pushrod depth as the old one that I’ve been
> using
> > > for 16 years. That doesn’t mean it’s right, of course.
> > > Rick “who did not measure pushrod clearance” Denney
> > > On Wed, Sep 11, 2019 at 9:50 PM James Hupy via Gmclist <
> > > > If you have the P-30 mc, and you were not careful about the length of
> > the
> > > > operating plunger, you will have symptoms of low pedal "feel".
> > Especially
> > > > until the brake pads wear in to the new rotors. Careful break-in is
> > > > necessary, starting with light pedal pressure and gradually
> increasing
> > it
> > > > as the pads wear in. You will NOT have the same pedal feel even when
> > > broken
> > > > in.
> > > > Jim Hupy
> > > > Salem, Or
> > > > On Wed, Sep 11, 2019, 6:41 PM Carl Stouffer via Gmclist <
> > > > > Rick,
> > > > > When I installed the Chuck Aulgur Reaction Arm system, along with
> the
> > > > disc
> > > > > brakes, I had to unbolt the top of the rear calipers and tilt them
> so
> > > the
> > > > > bleeder screws were at the very top (highest point) so there was
> not
> > an
> > > > > air pocket trapped above the bleeder screw. This info came from
> Jim
> > K
> > > > > after I
> > > > > was having trouble getting all the air out.
> > > > > That said, the P-30 master cylinder and disc brake system has a
> > > > completely
> > > > > different feel than the stock system had. I got used to it.
> > > > > Carl Stouffer
> > > > > '75 ex Palm Beach
> > > > > Tucson, AZ.
> > > > > Chuck Aulgur Reaction Arm Disc Brakes, Quadrabags, 3.70 LSD final
> > > drive,
> > > > > Lenzi knuckles/hubs, Dodge Truck 16" X 8" front wheels, Rear
> American
> > > > > Eagles,
> > > > > Solar battery charging. GMCSJ and GMCMI member
> > > > > _______________________________________________
> > > > > GMCnet mailing list
> > > > > Unsubscribe or Change List Options:
> > > > GMCnet mailing list
> > > '73 X-Glacier 230 "Jaws"
> > > Northern Virginia
> > > Offlist email: rick at rickdenney dot com
> > > GMCnet mailing list
> Northern Virginia
